dartswinger71318
Does anyone have a source for a complete wheel bearing kit for a 1969 Dart disc brake setup, it's for a 4 piston K.H.
Thanks in advance
Thanks in advance
They all can get them for you if they don't have them on the shelf. I would suggest Timken, BCA, or National as quality brands.May i politely suggest just going over to any of your local parts stores, and getting them there.
FYI.
They are the same, listed for 10" inch Drum brakes.
Thank you, I was hoping to get the complete kit as opposed to individual bearings. I'll give NAPA a shot, the only issue is their books usually don't go back that far. I will try to get the #'s off the bearings I have and hope for the best.May i politely suggest just going over to any of your local parts stores, and getting them there.
FYI.
Thanks you for the information.May i politely suggest just going over to any of your local parts stores, and getting them there.
FYI.
Thank youAs mentioned, they should be on the shelf at any good auto parts store. A2 (or set#2) and A6 (set#6) are the bearings kits (race and cone). Grease seals (6840S National) should be easily available too. Individual bearing numbers are typically known as 11949 for the outer cone, 11910 for the outer race, 67048 for the inner cone, and 67010 for the inner race.
Thank you for the help.They all can get them for you if they don't have them on the shelf. I would suggest Timken, BCA, or National as quality brands.
