69 Dart GT Quarter Window Help
kybatman
The Original Bruce Wayne!
Bowie, Texas
can anyone post some pics down in the quarter of the Window and regulator.
I bought the kit and cannot wrap my brain around how it all goes back together.
I have all of the tracks back in the regulator and the part that attaches to the actual glass.
Thanks in advance.
Bruce
I am in the middle of doing this right now. It looks as though the tracks are installed AFTER the regulator and glass have been installed.
1. Regulator
2. Glass assembly
3. Unbolt regulator and attach rear reg roller to its slot (FYI rear reg arm roller shares space with the rear channel guide roller) then reposition to slide front reg roller in its spot.
4. Slide smaller reg pivot into welded slot on frame work and bolt up regulator.
5. Slide rear guide onto roller and attach to frame.
6. Slide front guide through rollers and attach to frame and bottom brace.
7. Install stops and adjust
I
step 3 is the part i am having issue with, i do not know which roller goes there.
This part of my car was removed while i was out of town and the guy that took them apart no longer works at the shop.
Bruce
