69 Dart rear tranny support (cross-over info needed)
MVRCorp
So I have a 69/727/Dart support I'm throwing on ebag. Who has a cross-over manual that can tell me what other cars/years does it fit on?
.............67-69 use 1/2 in bolts. 70-72 use 3/8 bolts.....kim.....
Same pattern? So they can be drilled out to a larger size? Just trying to
figure out how to list this.
.............It fits only 67-69 A bodies.......i say this because u "can" install it on a 70-72 A body but the holes r 2 big on the crossmember so u would need big washers welded to it 4 the 3/8s bolt size as the cm is a support 4 the body as well.......u cannot drill out the body anchor 4 bigger bolts........kim..........just list it 4 67-69 A body dart, cuda
