[FOR SALE] 69 up automatic console wiring harness "NEW"
moparmat2000
Grand Tetons
A body 69 and up automatic console shifter indicator wiring sub harness with stub harness that connects to fuse box. This is correct length with correct ends. New 16ga wire, new connectors. Bulb socket is reconditioned OEM used. Comes with Phillip's self tapping ground screw. May fit newer than 1969 consult your FSM for any differences.
Wiring routing for this in a 1969 was routed across passenger side floorboard and up passenger side behind kick panel. Ground terminal is attached to sheetmetal behind kick panel. The single orange wire runs up and across the bottom of the dash in with the other wire bundles. It ties in at the instrument panel lamp jumper male spade connector in the fuse box. Consult your FSM for routing and connections as this is how its routed and connected for 1969.
$80 plus USPS current flat rate shipping. Located in west Texas I accept PayPal.
