69 Valliant grille on a 70 duster
Daniel J Thurston
Active Member
N.Y
Hi I bought a 69 grille for my 70 duster I was told it will just bolt up but it dose not the hood latch pannel dosent ine up and there is a huge gap between hood I think I may need the lower filler pannel from the 69 valiant has anyone done this swap before and can help me out to get it to look ok thanks
DAN
Thanks for the quick response I can use any info anyone has any info please let me know I cant seem to find anything helpful in seartch function
I just did a search function on this site with “Valiant grill” and got several threads that talk about installing a ‘69 grill on ‘70+ A bodies give it a try and find out since they are there as it’s been talked about many times over the many years which should provide the info you after
Ok that helped a lot I had to take out the rivet on the grille and beans the tabs on the upper valance ? Idk what it is but I think it looks right what you all think
Are you happy with it?
DAN
You text a lot, don't you?
:lol:
