-6an for transmission lines?
Transmission and Drivetrain Tech
  1. StewsDart
    StewsDart Member
    24
    5
    Mar 22, 2018
    Western New York
    Local Time:
    2:19 PM
    I am at the point in my build now to run new transmission cooler lines. I am going to be running into the radiator then from radiator to a cooler back to the trans. I am wondering about running dash 6 braided line, has anyone done this? If so what will I need for fittings from a 904 trans? Also other people’s insight or ideas would be appreciated too. Thanks in advance,
    Jake
  2. 67Dart273
    67Dart273 Well-Known Member
    38,998
    6680
    Oct 14, 2010
    Idaho
    Local Time:
    11:19 AM
    Adapters are no problem, the trans is pipe thread. AN fittings are same as JIC, used in tractor/ industrial hydraulics. A no6 JIC/AN to pipe thread is easy to get. Don't remember if they are 1/4 or 1/8 offhand
    "The trick" is that AN/ JIC are 37 degree flare, the original inverted flare or male flare (brass) are 45 degree. No5 (5/16) will screw together but the flare angle is different. No6 JIC/AN is a different thread than no6 SAE (45 degree)
  3. scott657
    scott657 Well-Known Member
    327
    103
    Dec 26, 2016
    Lancaster, Ca
    Local Time:
    11:19 AM
    Just did this, -6 to 1/8 pipe at the trans and radiator
  4. SGBARRACUDA
    SGBARRACUDA ROY FABO Gold Member
    13,397
    3076
    Dec 7, 2006
    PLANT CITY FL.
    Local Time:
    2:19 PM
    I ran 6 AN from the trans to a separate log style cooler mounted under the radiator on the front valance. The only picture I could find that shows the cooler.
  5. 72Dart6pack
    72Dart6pack Harder Better Faster Stronger.
    2,825
    1859
    Feb 1, 2016
    Roseville Michigan
    Local Time:
    2:19 PM
    Question of the day! Do people know what AN stands for? Yes I know the answer?
    Post your thoughts.
  6. SGBARRACUDA
    13,397
    3076
    Dec 7, 2006
    PLANT CITY FL.
    Local Time:
    2:19 PM
    I too know.
  7. 72Dart6pack
    2,825
    1859
    Feb 1, 2016
    Roseville Michigan
    Local Time:
    2:19 PM
    Most people don't. But we have very smart FABO members. Someone will chime in.
  8. 70aarcuda
    70aarcuda Master Hoader of SBM FABO Gold Member
    14,075
    2140
    Jan 16, 2005
    las vegas
    Local Time:
    11:19 AM
    Army Navy....
    • Agree Agree x 1
    • 70aarcuda
      14,075
      2140
      Jan 16, 2005
      las vegas
      Local Time:
      11:19 AM
      I use 1/8 npt to #6 braided line from the trans to separate cooler in front of car...cooler has #6 filling on it...
    • ocdart
      ocdart Inland Mopars Car Club FABO Gold Member
      9,052
      1383
      Nov 5, 2006
      North OC, SoCal
      Local Time:
      11:19 AM
      Exactly!
    • SGBARRACUDA
      13,397
      3076
      Dec 7, 2006
      PLANT CITY FL.
      Local Time:
      2:19 PM
      Army Navy.... 10-4
      • Agree Agree x 1
      • pishta
        pishta I know I'm right....
        13,904
        3610
        Oct 13, 2004
        Tustin, CA
        Local Time:
        11:19 AM
        Another fun fact is the 6 in 6AN is 6/16ths or 3/8. Its all in 16ths , 20AN is 1 1/4"
        • Agree Agree x 2
        • 72Dart6pack
          2,825
          1859
          Feb 1, 2016
          Roseville Michigan
          Local Time:
          2:19 PM
          New question. BSPP? Any guesses? Lol
        • SGBARRACUDA
          13,397
          3076
          Dec 7, 2006
          PLANT CITY FL.
          Local Time:
          2:19 PM
          British Standard Pipe Parallel Thread. Or pipe thread fittings.
        • 68cuda408
          68cuda408 FABO Gold Member FABO Gold Member
          419
          110
          Jun 4, 2013
          11967 NY
          Local Time:
          2:19 PM
          Here's what I did.-6 with the line going straight to the gap in the lower inner fender to clear the linkage and headers and aluminum to the front cooler. I have dual 2 speed fans (contour) controlled by the ECM to pull steady air. I have stock grill openings in the glass nose so flow isn't an issue.
          • Like Like x 1
          • famous bob
            famous bob mopar misfit
            11,469
            2899
            Aug 14, 2011
            okla
            Local Time:
            1:19 PM
            army/navy
          • famous bob
            11,469
            2899
            Aug 14, 2011
            okla
            Local Time:
            1:19 PM
            I`m surprised no trans. people have jumped in here, and said anything about the trans. threads not being "EXACTLY'' 1/8" pipe. they are close and will take 1/8" fittings, but they are not exactly 1/8" pipe . Anyone notice the diff. ??
          • 69_340_GTS
            69_340_GTS Well-Known Member
            3,112
            1077
            Jul 11, 2014
            Torrington, CT
            Local Time:
            2:19 PM
            • Like Like x 1
            • sireland67
              sireland67 Well-Known Member
              7,638
              1657
              Oct 27, 2010
              WV
              Local Time:
              2:19 PM
              That is a clean install.
            • 68cuda408
              419
              110
              Jun 4, 2013
              11967 NY
              Local Time:
              2:19 PM
              Thank you
            • StewsDart
              StewsDart Member
              24
              5
              Mar 22, 2018
              Western New York
              Local Time:
              2:19 PM
              Can you post or send me pics of your install? I’m going to be doing pretty much the same exact setup
            • SGBARRACUDA
              13,397
              3076
              Dec 7, 2006
              PLANT CITY FL.
              Local Time:
              2:19 PM
              I thought I had more pictures of it but I didn't. If I get it up on the lift soon I'll take more pictures.
            • StewsDart
              StewsDart Member
              24
              5
              Mar 22, 2018
              Western New York
              Local Time:
              2:19 PM
              Thanks I’m just curious as to where/how you mounted the cooler and line routing
            • StewsDart
              StewsDart Member
              24
              5
              Mar 22, 2018
              Western New York
              Local Time:
              2:19 PM
              Super clean install
            • 68cuda408
              419
              110
              Jun 4, 2013
              11967 NY
              Local Time:
              2:19 PM
              Thank you
