1. Avispa
    Avispa FABO Gold Member FABO Gold Member
    926
    375
    Feb 26, 2007
    Georgia
    Local Time:
    2:23 PM
    I had a rear DS wheel lock up, after removing the drum, (a 9 inch drum) I found this broken spring.
    I posted over in the wanted section for a spring, BlackHatGuy came through and sent me some hardware of of a 7 1/4 his car had just broken. Here's a pic of the spring he sent, the good spring from the opposite side of My car, and the broken spring I need to replace, NAPA ordered the kit, but when it came in the parts were not correct.
    I did try the spring BHG sent, but just by the way it's made, the overall length and the length of the coils it looks like it would interfere with the brake adjuster.
    Does anyone know why there's a difference, venture a guess as how to fix it, or possibly have a spring I can buy?
  2. 4spdragtop
    4spdragtop FABO Gold Member FABO Gold Member
    26,369
    5914
    Aug 28, 2009
    Ontario
    Local Time:
    1:23 PM
    I have springs and a 7 1/4 here, your more than welcome to. Red spring for ds or ps?
  3. Avispa
    926
    375
    Feb 26, 2007
    Georgia
    Local Time:
    2:23 PM
    Is it shaped like the two at the top in the picture? The broken one was on the DS, the other one from the PS looks exactly the same (to Me)
  4. halifaxhops
    halifaxhops It's going to get stupid around here! FABO Gold Member
    52,534
    20564
    Jan 20, 2014
    CENTRURAL, PA
    Local Time:
    2:23 PM
    That was put on backwards the long section goes over the star wheel area.
  5. Avispa
    926
    375
    Feb 26, 2007
    Georgia
    Local Time:
    2:23 PM
    yes, for clearance, right?
  6. halifaxhops
    52,534
    20564
    Jan 20, 2014
    CENTRURAL, PA
    Local Time:
    2:23 PM
    Yes was prob rubbing up and down and stressed it
  7. Avispa
    926
    375
    Feb 26, 2007
    Georgia
    Local Time:
    2:23 PM
    So, adj wheel to the rear and hook end to the front, that should clear, right? and the offsets on the non hook end are for the star wheel clearance, right?
  8. 4spdragtop
    26,369
    5914
    Aug 28, 2009
    Ontario
    Local Time:
    1:23 PM
    Not sure if this is right one? Mine is hooked at both ends and 5" end to end.
  9. Avispa
    926
    375
    Feb 26, 2007
    Georgia
    Local Time:
    2:23 PM
    small hook to the shoe and large to the adjuster?
    Naw, can't be right, this spring is used to put tension on the shoes to hold the bottom of the shoes in, I guess, gotta have something putting tension on them.
    Only I could get a 1 of 1 and it be the brakes ! :)
    I just left the drums off so I could move it, be awhile before it's on the road, I've googled, Youtubed, and Ebayed it, came up with nothing.
  10. 4spdragtop
    26,369
    5914
    Aug 28, 2009
    Ontario
    Local Time:
    1:23 PM
    Well i cant decipher your reply and that doesnt tell me if those will work or not.....good luck
  11. Avispa
    926
    375
    Feb 26, 2007
    Georgia
    Local Time:
    2:23 PM
    ok thanks
  12. Blackhatguy
    Blackhatguy Well-Known Member
    168
    74
    Dec 20, 2017
    Texas
    Local Time:
    1:23 PM
    I'll post this here for you. I tried sending this to you in our conversation but the site won't let me do pictures there.
    This is a diagram of the 9 inch Dodge Dakota brakes, lower spring and adjuster set up look familiar?
    • Agree Agree x 1
    • halifaxhops
      52,534
      20564
      Jan 20, 2014
      CENTRURAL, PA
      Local Time:
      2:23 PM
      • Agree Agree x 1
      • Avispa
        926
        375
        Feb 26, 2007
        Georgia
        Local Time:
        2:23 PM
        BINGO !! Yep, that's gotta be it, I had a feeling someone had bastardized it, man, appreciate the help!!
        • Like Like x 1
        • Avispa
          926
          375
          Feb 26, 2007
          Georgia
          Local Time:
          2:23 PM
          OK, yes, it's puree'd, but the question is answered, and ain't that what this place is supposed to be about?
          • Agree Agree x 1
          • Blackhatguy
            168
            74
            Dec 20, 2017
            Texas
            Local Time:
            1:23 PM
            Well, now that we know what you're working with, you got two choices. those things I sent you can be used to restore it back to its original configuration, or you can go get another brake hardware kit for the Dakota to keep it as it is now. Honestly, not altogether too certain that the Dakota adjuster is not a better design...
          • Avispa
            926
            375
            Feb 26, 2007
            Georgia
            Local Time:
            2:23 PM
            good point, better get off of here now so Halifax can get some peace and quiet! :)
            I'm gonna go with the new stuff ya sent, thanks again.
            Roger
          • Blackhatguy
            168
            74
            Dec 20, 2017
            Texas
            Local Time:
            1:23 PM
            Good luck!
