Apr 7, 2026 #1 Badvert65 Long Time Mopar Nut Joined Sep 21, 2014 Messages 475 Reaction score 304 Location Brightwood, VA Does anyone know if swapping in an 8 1/4 rear (replacing the 7 1/4) will cause driveshaft problems-as far as length is concerned? This is in a 71 Scamp.
Apr 7, 2026 #2 doogievlg Well-Known Member Joined Nov 13, 2007 Messages 8,520 Reaction score 2,556 Location Amelia, Ohio You will need to have the drive shaft shortened. Not a huge deal and doesnt cost a ton.
Apr 7, 2026 #3 C cop car wagon Well-Known Member Joined Mar 11, 2026 Messages 73 Reaction score 62 Location Everett wa And the bigger shock plates with u bolts. That only problem is more money.
Apr 8, 2026 #4 Dana67Dart The parts you don't add don't cause you no trouble FABO Gold Member Joined Jul 16, 2017 Messages 20,069 Reaction score 17,541 Location Northern Colorado If your shaft is the insulated 2 piece design like in 67 best to just replace it And different flex hose from the body to the rear axle housing. And U-joints MIGHT be different, you most likely have 7260 (small) U-joints on the drive shaft and I don't know what you have on your 8 1/4
Apr 8, 2026 #5 Jim Kueneman FABO Gold Member FABO Gold Member Joined Jul 26, 2016 Messages 4,273 Reaction score 9,427 Location Sonoita, Az You need shock plates, U-bolts and a shorter drive shaft. I believe it was the same as having an 8.75 in it. The Valiant has a 8.25"
Apr 11, 2026 #6 T timk225 Well-Known Member Joined Jun 2, 2024 Messages 353 Reaction score 164 Location Pittsburgh All else being equal, the 8-1/4" requires a driveshaft 1.60" shorter than a 7-1/4". I found a list here recently showing all the differences.
