70 dart 340 4speed fan
Heating / Cooling / AC
  1. Jarod340
    Jarod340 Active Member
    34
    5
    Feb 20, 2017
    Petaluma, ca
    Local Time:
    7:48 AM
    I'm trying to figure out what's the correct fan,on my 70 dart 340 4speed car w/ no AC. I have a 5 blade fan and a 18" fan with 7 blades...
  2. Sublime Swinger
    Sublime Swinger Well-Known Member
    166
    41
    Sep 15, 2013
    Minnesota
    Local Time:
    9:48 AM
    2863215
    • Agree Agree x 2
    • Sublime Swinger
      166
      41
      Sep 15, 2013
      Minnesota
      Local Time:
      9:48 AM
    • toolmanmike
      toolmanmike Moderator Staff Member FABO Gold Member
      63,406
      53461
      Jan 18, 2006
      Iowa
      Local Time:
      9:48 AM
      N51 cooling option?
    • Jarod340
      34
      5
      Feb 20, 2017
      Petaluma, ca
      Local Time:
      7:48 AM
      I can't find those part numbers on it...there is p16219 on the fan and blades say 3870 107 2465
    • Jarod340
      34
      5
      Feb 20, 2017
      Petaluma, ca
      Local Time:
      7:48 AM
      Not sure what n51 is? I do not have a build sheet
    • Sublime Swinger
      166
      41
      Sep 15, 2013
      Minnesota
      Local Time:
      9:48 AM
      Would be ink stamped or impression stamped at the end of the blade like this.
      • Agree Agree x 1
      • toolmanmike
        63,406
        53461
        Jan 18, 2006
        Iowa
        Local Time:
        9:48 AM
        N51 is heavy duty cooling. If you don't have a fender tag or build sheet you may not know for sure.
      • hosehead
        hosehead Well-Known Member
        1,183
        976
        Dec 4, 2008
        Grand Lake o the Cherokees
        Local Time:
        7:48 AM
        Anyone have a pic of the actual fan?
      • George Jets
        George Jets 1967 Dart 2 Door FABO Gold Member
        5,926
        8114
        Jan 18, 2019
        Farmington MN
        Local Time:
        9:48 AM
        Yep here it is 2863 215
      • hosehead
        1,183
        976
        Dec 4, 2008
        Local Time:
        7:48 AM
        Mine has no numbers but it has a pentastar and looks the same. Besides someone removing the clutch.
      • TrailBeast
        TrailBeast AKA Mopars4us on Youtube
        21,696
        9667
        Mar 11, 2011
        Arizona
        Local Time:
        8:48 AM
        Note that fans that had clutches on them have a different larger center and bolt pattern.
        The pictured fan was never clutched.
        • Like Like x 1
        • George Jets
          5,926
          8114
          Jan 18, 2019
          Farmington MN
          Local Time:
          9:48 AM
          They move lots of air and run quiet too.
          Had a 6 blade solid mount on a 74 Dart Swinger AC car. That fan made so much noise when it would spin up it sounded like there was a Prop Airplane under the hood.
          So yeah, when you got one that runs quiet that is pretty darn nice.
        • George Jets
          5,926
          8114
          Jan 18, 2019
          Farmington MN
          Local Time:
          9:48 AM
          That looks like a Clutch Style Fan with an Adapter to make it a solid mount fan, not sure why someone would want to do that . . . if anything I would think you would want to go for the Clutch.
        • hosehead
          1,183
          976
          Dec 4, 2008
          Local Time:
          7:48 AM
          Absolutely. Just removed the adapter and will search for the correct clutch tonight.
        • George Jets
          5,926
          8114
          Jan 18, 2019
          Farmington MN
          Local Time:
          9:48 AM
          What engine, what car??
          Small Block, Big Block ??
          Here is the fan clutch I used with the 69 small block 318 (Red) above.
          Have a part number too for that real short fan clutch if it is too close to the radiator.
        • 72Dart6pack
          72Dart6pack Harder Better Faster Stronger.
          4,809
          5363
          Feb 1, 2016
          Roseville Michigan
          Local Time:
          10:48 AM
          Easy to see this part number.
        • George Jets
          5,926
          8114
          Jan 18, 2019
          Farmington MN
          Local Time:
          9:48 AM
          Gee, by the looks of that short adapter think you are going to need that short fan clutch.
        • George Jets
          5,926
          8114
          Jan 18, 2019
          Farmington MN
          Local Time:
          9:48 AM
          Short fan Clutch
        • hosehead
          1,183
          976
          Dec 4, 2008
          Local Time:
          7:48 AM
          70 340 swinger
        • George Jets
          5,926
          8114
          Jan 18, 2019
          Farmington MN
          Local Time:
          9:48 AM
          Nice
          Thinking that takes the short clutch with a stock A Body radiator and fan shroud. Double check to make sure.
        • oldkimmer
          oldkimmer FABO Gold Member FABO Gold Member
          20,809
          7729
          Nov 11, 2006
          Kindersley, Saskatchewan,
          Local Time:
          9:48 AM
          I have a factory declutching fan from my 70 swinger 340 car. No a/c. Kim
        • TrailBeast
          21,696
          9667
          Mar 11, 2011
          Arizona
          Local Time:
          8:48 AM
          Ah ha, I didn't notice that was an adapter.
