70 Dart. Looking for More Castor, QA1 arms or Moog bushings?
Suspension, Steering and Chassis
  1. 340doc
    340doc Well-Known Member
    2,016
    516
    May 8, 2010
    Hollywood Fl
    Local Time:
    7:58 AM
    1970 Dart with large ball joint uppers. The QA1 arms state 3 degrees more castor. How much can I get with the Moog offset bushings? Anyone use these QA1 arms? What's the quality? QA1-52301 Thanks.
  2. brian6pac
    brian6pac Well-Known Member
    3,171
    1692
    Nov 15, 2016
    N.E.Ohio
    Local Time:
    7:58 AM
    moog offset bushing
  3. 340doc
    2,016
    516
    May 8, 2010
    Hollywood Fl
    Local Time:
    7:58 AM
    I'm ok with them, they save me some bucks. Curious to know though, how much gain with the bushings compared to the arms.
  4. toolmanmike
    toolmanmike FABO Staff Staff Member FABO Gold Member
    35,205
    17182
    Jan 18, 2006
    Iowa
    Local Time:
    6:58 AM
    Doc, After you get it done let us know how it drives. It has to help give the car some road feel to make up for Mopar's over zealous power steering.
  5. Streetsboro Rick
    Streetsboro Rick Well-Known Member
    136
    56
    Apr 27, 2018
    Streetsboro Ohio
    Local Time:
    7:58 AM
    Have the QA1 arm on my Duster nice pieces
    • Agree Agree x 2
    • Thanks! Thanks! x 1
    • 340doc
      2,016
      516
      May 8, 2010
      Hollywood Fl
      Local Time:
      7:58 AM
      Will do.
    • 340doc
      2,016
      516
      May 8, 2010
      Hollywood Fl
      Local Time:
      7:58 AM
      Fit was good, no issues? How long have you been running them?
    • Streetsboro Rick
      136
      56
      Apr 27, 2018
      Streetsboro Ohio
      Local Time:
      7:58 AM
      Fit nicely had them on for 2 years
    • 340doc
      2,016
      516
      May 8, 2010
      Hollywood Fl
      Local Time:
      7:58 AM
      Thanks Rick
    • GMachineDartGT
      GMachineDartGT Senior Member
      1,424
      132
      May 9, 2006
      203 West Hills Road
      Local Time:
      7:58 AM
      The QA1 arms are the nicest tubular arms on the market. They also allow for clearance of high offset wheels should you desire to go wide. I run 18x9s on the front. The offset bush ings do not allow as much positive caster and are rubber which allows a lot of flex.
      Furthermore, don't get too caught up with excessive caster, 3 degrees is fine. Most guys with high caster don't realize there is a jacking effect in turns which is very unsettling at speed. I run my car on the track occasionally and run about 4 degrees.
      • 340doc
        2,016
        516
        May 8, 2010
        Hollywood Fl
        Local Time:
        7:58 AM
        Thanks Gmachine. For the people who use the offset bushings, are you able to get, say 3 degrees castor?
      • inertia
        inertia Well-Known Member
        3,087
        424
        Feb 4, 2011
        Victoria B.C. Canada
        Local Time:
        4:58 AM
        I've used over 1/2 dozen sets, never failed to get 2* caster, they may do more, I never tried,
        The couple I couldn't get enuff had bent stuff.
        3* caster is an awful lot, you're sorta starting to shooting at the moon then, your wheels are toed kinda up, and there's other issues.
      • 340doc
        2,016
        516
        May 8, 2010
        Hollywood Fl
        Local Time:
        7:58 AM
        Thank you. I was wondering what numbers were within reach with the bushings.
      • inertia
        3,087
        424
        Feb 4, 2011
        Local Time:
        4:58 AM
        I only align to 2*, so I never tried for more cuz it causes a really heavy steering wheel to turn at slow speeds, in parking lots, etc. as a daily driver.
        I run lots and lots caster in the RF of my racecar to help turn left.
        What is your goal for the car, road-racing ? ?
        cheers
      • 340doc
        2,016
        516
        May 8, 2010
        Hollywood Fl
        Local Time:
        7:58 AM
        I'm just looking for a fun street car. Just put on some good 17" rubber and want to keep going. The car needs to go for an alignment and I want to have everything in place for a one and done on the alignment. I've heard many times on this site, that not enough caster is available with all stock pieces. That's why I was inquiring about the arms and bushings. Do you know what the most caster you can get with all stock pieces?
      • 72bluNblu
        72bluNblu FABO Gold Member FABO Gold Member
        9,036
        3007
        Nov 28, 2008
        NorCal
        Local Time:
        4:58 AM
        You won't get much more than +3* of caster with the offset bushings, I certainly wouldn't count on getting more than that. Depending on the ride height, you might not be able to get that much.
        +3* is not "an awful lot" of caster. Most modern cars run between +6* and +8* of caster. Yes, how much you want is dependent on the suspension design, so that's not strictly an apples-to-apples comparison. But +3* still isn't a lot for the A-body suspension.
        I've run everything from about +3* up to +8* of caster on my Duster, starting by using stock UCA's with offset bushings and now running SPC UCA's from Bergman AutoCraft. I'm currently running +6.5* of caster. There is a "jacking" effect, but the additional positive caster also increases the negative camber on turn in (which is where that jacking effect comes from). It's a bit of a balancing act, and it does depend on driving style and preference too, in addition to how the rest of the car is set up. Peter obviously likes to run less, and I'm sure he has a great reason for it because I know he can get more caster if he wanted it. I personally like where my car is at with +6.5*, but I also wouldn't say that's the right answer for everyone.
        For a street car with decent tires I think +3* is the least that I would want to go. That's just me. And that would be pretty much the limit of the stock UCA's and offset bushings.
      • 340doc
        2,016
        516
        May 8, 2010
        Hollywood Fl
        Local Time:
        7:58 AM
        Please describe what a Jacking affect is.
      • 72bluNblu
        9,036
        3007
        Nov 28, 2008
        NorCal
        Local Time:
        4:58 AM
        When you turn the steering, the inside front wheel is lowered, and the outside front wheel is raised. That in turn raises the mass of the car, and puts more of the weight on the inside front and outside rear wheel.
        There's a bunch of things that effect how much jacking you get, caster is one of them, but so is the scrub radius you have up front and the amount of camber you already have dialed in. Typically though the more caster you have, the more jacking you get (unless the scrub radius is zero, but it isn't).
        On turn in the caster is a good thing, but if you have a large amount jacking you can get a significant weight shift, which tends to destabilize the car right after turn in. There are a ton of other effects too, it depends a lot on the rest of the suspension geometry. So the amount of jacking you get depends on how your car is set up, and how much it effects handling depends on what you're doing with the car.
        Like anything in suspension, there are trade-offs, and getting the car to handle right for what you're doing with it is a balancing act. Some jacking is good, it tends to counter the overall weight shift to the outside and keep weight on the inside front tire. Too much is bad, you end up moving too much weight around as you enter the corner and you can get an opposing weight shift right after turn in, which is bad.
      • 340doc
        2,016
        516
        May 8, 2010
        Hollywood Fl
        Local Time:
        7:58 AM
        I get it. Thank you for explaining that blu.
