Did the factory rad for a 70 Duster 340 with A/C come with a 3 core rad?
Thanks
Stu.
Thanks
Stu.
Yes. I have one. It’s a factory 318 a/c car (now crate 402 ) which is the same as 340 max cooling pkg. #2998945Did the factory rad for a 70 Duster 340 with A/C come with a 3 core rad?
Thanks
Stu.
I found this info which lists the rad for a 70 340 with A/CI believe the only way to correctly ID which radiator the factory installed is to reference the Build Sheet. The 2 numbers under "RAD" indicates the radiator part #
(line 3 on my 70 dart 340 build sheet)
Then look up in factory parts manual and/or one of Govier books
ex build sheet 45 = 2998945 = 70 340 both trans with N51 max cooling package
This is a 3 core radiator
78 = 2998978 = 70 340 both trans
This is a 2 core radiator
These are the only 340 radiators offered on 1970 A bodies
Above info from Govier books and there is no listing for a 70 340 with a/c
I have both radiators and info is correct
Anyone with more info can add to this
Edit. Mine is a 2998944. 318 with A/CYes. I have one. It’s a factory 318 a/c car (now crate 402 ) which is the same as 340 max cooling pkg. #2998945
Thank you for chiming in!I had my 2 core recored to 3 core. Rad guy said it's a straight forward rebuild.
