I was given this 1970 slant 6 225. It is out of a 1970 Cuda. All I needed was the distributor and the carb. They said it was just taking up space and wanted it gone. I need under dash wiring for my `68 Valiant v100 slant 6 225. There is no wiring from the bulkhead back.. It is loaded in the back of my pickup on a pallet ready to deliver( in Utah). You must have a way to take it out if I deliver it.( Gas for delivery is required) I will Even swap for the wiring I need. I was told the engine is fine, just upgraded the car with a 340. That`s all I know. I only took the distributor and carb. Message me if you have what I need, or if you or anyone you know needs a #`s 70 motor Slant 6 225. Thanks
