matthon
- Joined
- Aug 29, 2008
- Messages
- 2,963
- Reaction score
- 1,319
71 383 HP with a stock 4 barrel intake, complete except no carb, 346 heads. Assumed 8.5:1 compression.
Pulled valve covers and exhaust manifolds, looks clean, been sitting inside a friend's heated garage for years.
Going in car with headers, dual exhaust, and a 4 speed, crank has correct hole/bearing.
I have extra parts from another 383, including a Performer RPM intake and Holley 750, (also a tunnel ram and matching 600s).
Small budget, looking to make it run again.
What would be the best thing to spend a few dollars on?
Is the RPM/Holley combo possible as is, or with a new cam?
Or does the compression ratio need to be improved first?
With possibly a used set of heads.
My understanding is a set of closed chambered heads would raise the compression ratio. I have a set of 915s, however one of the 915s was machined below the springs and spacers used. I have the valves, springs, shims, etc, to put them back together but beyond my skill level, and not sure if it is even realistic.
