[WANTED] 71 Swinger Instrument Cluster
Cars and Mopar Parts Wanted
Thread Status:
  1. Alexhetti
    Alexhetti Well-Known Member
    88
    29
    Aug 19, 2020
    North Carolina
    Local Time:
    6:08 AM
    Contact Seller
    Looking for a non-rallye instrument cluster for a 71 swinger. Doesn’t need to be perfect but would like for all gauges to be functional.
    • Like Like x 1
    • Alexhetti
      88
      29
      Aug 19, 2020
      North Carolina
      Local Time:
      6:08 AM
      bump
    • str12-340
      str12-340 FABO Gold Member FABO Gold Member
      2,777
      1926
      Dec 26, 2012
      Vashon, WA
      Local Time:
      3:08 AM
      I have a bunch of these disassembled. If you are interested in putting one together send a PM. By the way, in any case there are temp and gas gauges available new with an updated design - much better than stock (I got mine from Herb's but check around for the best price including shipping). I would also recommend a transistorized voltage limiter to replace the original.
    • Alexhetti
      88
      29
      Aug 19, 2020
      North Carolina
      Local Time:
      6:08 AM
      I’m mainly looking for one with a working speedometer. That gauge has been unhooked since i’ve had my car because it does a full sweep back and forth that increases with rpms. It makes an incredibly annoying ticking noising the entire time
    • 1500swinger
      1500swinger it's for sale not on sale
      318
      69
      Jul 2, 2011
      bonnyville
      Local Time:
      5:08 AM
      Sounds like your speedo cable needs to be lubricated.
      • Like Like x 1
      • Alexhetti
        88
        29
        Aug 19, 2020
        North Carolina
        Local Time:
        6:08 AM
        You think that’s the cause? I really though that the actual gauge might be broken.
      • 1500swinger
        318
        69
        Jul 2, 2011
        bonnyville
        Local Time:
        5:08 AM
        When the needle starts bouncing its from sticky cable. Pull cable out of casing lube and reinstall.
        • Like Like x 1
        • 1500swinger
          318
          69
          Jul 2, 2011
          bonnyville
          Local Time:
          5:08 AM
          That or speedo cable outer sheath is cracked, bent etc.
          • Like Like x 1
          • Alexhetti
            88
            29
            Aug 19, 2020
            North Carolina
            Local Time:
            6:08 AM
            I’ll try replacing the cable then. The needle isn’t really bouncing, its basically rapidly sweeping from 0 to 120. I wish I had a video to show it. I unhooked the cable and now the needle is parked at 120…so I’m always speeding lol
          • QuickBpBp
            QuickBpBp Well-Known Member
            1,303
            960
            Jan 29, 2012
            Narvon Pa.
            Local Time:
            5:08 AM
            I have a good speedometer from one..
          • Alexhetti
            88
            29
            Aug 19, 2020
            North Carolina
            Local Time:
            6:08 AM
            PM me
          • QuickBpBp
            1,303
            960
            Jan 29, 2012
            Narvon Pa.
            Local Time:
            5:08 AM
            Here it is.. Pulled many years ago was a parts cluster and just been sitting. It's not mint just a good working speedometer... $20 plus shipping let me know any interest..
          • Alexhetti
            88
            29
            Aug 19, 2020
            North Carolina
            Local Time:
            6:08 AM
            • Thanks! Thanks! x 1
            • QuickBpBp
              1,303
              960
              Jan 29, 2012
              Narvon Pa.
              Local Time:
              5:08 AM
              Thanks Good to know. I thought they switched to this style in '71 for standard dash.. I did have a '71 & '72 Swinger both parted 2 decades ago...So this must have come out of the '72..
              • Like Like x 1
              • QuickBpBp
                1,303
                960
                Jan 29, 2012
                Narvon Pa.
                Local Time:
                5:08 AM
              • Alexhetti
                88
                29
                Aug 19, 2020
                North Carolina
                Local Time:
                6:08 AM
                looks like you’re checking out a demon cluster…not a swinger which I specified
                • Agree Agree x 1
                Thread Status:
