mopardemon340
i need the change the brake pedal ratio but i need some help with it.. right where i need to drill my hole is the bend in the pedal lever to take it around the steering shaft. also my hydro boost is mounted where the original Mc was making the push road to angled down. with it angled down will the down will that be an issue. cant move the HB cause of clearance. any help or ideas would be appreated.
