72 duster 360 NA to 390 Turbo
Forced Induction Mopar
  1. dusted
    dusted FABO Gold Member FABO Gold Member
    301
    234
    Sep 24, 2006
    Creedmoor, NC
    Local Time:
    9:21 AM
    Bought this car in 98. It was 318,727, small rear driver. Paid $1000 for it and it was delivered to my house. It sat for a couple of years and I went decided the time was right. Began by converting it to big bolt pattern, change rear to 8 3/4, new exhaust changed carb..y’all Know the drill.
    Drove like that for many years and decided to go 360 and I wanted to go magnum.
    Fixed a 98 360, M1 intake, 650vs Hughes cam, 2800 no name converter, Tti headers and exhaust stock everything else. Drove like this for years and all my buddy with there LS stuff went Turbo and convinced me to go also. So it began.
  2. dusted
    301
    234
    Sep 24, 2006
    Creedmoor, NC
    Local Time:
    9:21 AM
    Came back from Carlise, sold my Tti exhaust and headers. And began the parts gathering process
  3. dusted
    301
    234
    Sep 24, 2006
    Creedmoor, NC
    Local Time:
    9:21 AM
    Designed a hotside, mounted Turbo, converted carb to blowthru, my welding skill aren’t the best, to a special thanks to my cousin (project73) on here for his welding expertise and patience
  4. dusted
    301
    234
    Sep 24, 2006
    Creedmoor, NC
    Local Time:
    9:21 AM
    With all that done, turned my attention to the ignition. Used a MSD and added a limited to the distributor.
  5. dusted
    301
    234
    Sep 24, 2006
    Creedmoor, NC
    Local Time:
    9:21 AM
    Fuel was handled by a 044 Bosch pump and areomotive boost referenced regulator
  6. dusted
    301
    234
    Sep 24, 2006
    Creedmoor, NC
    Local Time:
    9:21 AM
    Battery in trunk
  7. dusted
    301
    234
    Sep 24, 2006
    Creedmoor, NC
    Local Time:
    9:21 AM
    Here it is after it was done and madien voyage. Spinning at 50mph, barely see the marks. This was on 6 psi and a 11.8 afr
  8. dusted
    301
    234
    Sep 24, 2006
    Creedmoor, NC
    Local Time:
    9:21 AM
    Never dynoed or made it to the track before I hurt this combo. Actually It wasn’t my fault (this time), my wastegate reference came off and who know that the boost was before it went pop.
    Sold the engine to my cousin who fixed an couple of pistons and headgaskets which had broke and put it back together and is driving it right now this combo minus the turbo and intake.
  9. dusted
    301
    234
    Sep 24, 2006
    Creedmoor, NC
    Local Time:
    9:21 AM
    I kept my heads also.
  10. dusted
    301
    234
    Sep 24, 2006
    Creedmoor, NC
    Local Time:
    9:21 AM
    So that brings us to the combo now.
    390ci magnum block, Fully forged Icon pistons, I believe scat crank and rods. I bought it from my nephew who assembled it for a customer who went MIA when it was done.
    • Like Like x 1
    • dusted
      301
      234
      Sep 24, 2006
      Creedmoor, NC
      Local Time:
      9:21 AM
      Called Hughes and he specked me a turbo cam and valve springs. Had to cut the heads for the springs to be at the right installed height. Believe we cut 80 thousands from the seat
    • dusted
      301
      234
      Sep 24, 2006
      Creedmoor, NC
      Local Time:
      9:21 AM
      Cam specs
    • dusted
      301
      234
      Sep 24, 2006
      Creedmoor, NC
      Local Time:
      9:21 AM
      The car is stupid fast on 6psi and it won’t be there for long. I need to go injected. Only drove maybe 10 miles and I have a lot of tuning to do. Not sure how long the TCI trans is gonna last but I will be sure to let y’all know when it breaks. Haven’t messed with the car couple of months, just walk by it in the garage. Sad I know.
      • Like Like x 2
      • dusted
        301
        234
        Sep 24, 2006
        Creedmoor, NC
        Local Time:
        9:21 AM
        Completed
        • Like Like x 4
        • dusted
          301
          234
          Sep 24, 2006
          Creedmoor, NC
          Local Time:
          9:21 AM
          I tried to be fairly generic with this post. If anyone has specific questions feel free to ask.
          BTW- This is what my cousin did with the old motor. Here are the cam specs of it. Runs just like it did minus turbo.
          • Like Like x 3
          • dusted
            301
            234
            Sep 24, 2006
            Creedmoor, NC
            Local Time:
            9:21 AM
            Magnum heads with LA valve cover before someone asks....
          • 67Dart273
            67Dart273 Well-Known Member
            39,018
            6705
            Oct 14, 2010
            Idaho
            Local Time:
            6:21 AM
          • Evan Dutch
            Evan Dutch Well-Known Member
            512
            99
            May 11, 2016
            monroe north carolina
            Local Time:
            9:21 AM
            Cool thread.
            • Like Like x 1
            • Thanks! Thanks! x 1
            • dusted
              301
              234
              Sep 24, 2006
              Creedmoor, NC
              Local Time:
              9:21 AM
              There is a large electric pusher fan in front of the radiator. It works fairly well but I wanna move the radiator forward or get a different one and mount a crown Vic’s fan in stock location. This is another reason I haven’t been driving this thing much. It’s been hot here in NC and I don’t trust the stock guage. Here is a lot of heat in there but I never had an issue with the old combo. Just a nervous precaution.
            • needsaresto
              needsaresto Well-Known Member
              7,794
              163
              Nov 13, 2004
              Local Time:
              6:21 AM
              Following. Very interesting.
              • Evan Dutch
                512
                99
                May 11, 2016
                Local Time:
                9:21 AM
                You’re not kidding about that NC heat. It’s too hot here.
              • dusted
                301
                234
                Sep 24, 2006
                Creedmoor, NC
                Local Time:
                9:21 AM
                More engine pics of downpipe and where it exits out the fender. It’s fairly loud! Haha!! My neighbors love me!
                Funny story, I live in a small town and all the cops go to the BP for gas at certain times. Last time I drove it I went there for gas and they were all there. They asked some questions about the car and then watched me drive away and get into some boost crossing the intersection. Love it!!!!
                • Like Like x 2
                • 360duster
                  360duster Well-Known Member
                  1,039
                  156
                  Nov 23, 2008
                  Bavaria / Germany
                  Local Time:
                  2:21 PM
                  cool stuff, i like it!
                  already thought about the routing of your exhaust pipe, now it´s clear ;-)
                  Michael
                  • Like Like x 1
                  • 73golddusterkid
                    73golddusterkid Gold Duster Kid
                    200
                    22
                    Feb 24, 2008
                    Kentucky
                    Local Time:
                    9:21 AM
                    Love it! Gives me so many ideas on my own Duster!
                    • replicaracer43
                      replicaracer43 Old school member
                      3,773
                      2217
                      Oct 10, 2008
                      Local Time:
                      8:21 AM
                      Where in NC are you?
