72 Duster build - Pro touring slant six
Members Restorations
  1. Red Stripe
    Red Stripe Well-Known Member
    62
    75
    Jul 19, 2012
    Mountain View
    Local Time:
    9:31 PM
    Thought I'd post up my 1972 Plymouth Duster build I am working on. Wanted a project that could be used while rebuilding it and this car fit the bill. It started life with a 225 slant six, 904 auto trans, 7.25 rear end, a/c, power steering, and manual drum brakes. Car fired right up and drove pretty decent but the tires were well beyond any usefulness and the brakes were nonexistent. Interior was a mess, had the funk of mice living inside but it was just about all there. Suspension was toast, nothing had been replaced in many years but I was ok with that as I like to add newer parts where needed.
    To start off I cleaned and then cleaned some more. Pressure washed everything a few times just to clean off the grime and added some paint and undercoating to the undercarriage for protection. The floors were almost perfect, aside from a 3” spot on the driver floorboard there was no rust at all. It took a while to clean out the mice nests but it cleaned up enough that you could actually sit in it and breathe. Anything that looked like the start of surface rust got covered in rust encapsulator so I shouldn’t have any issues pop up down the line.
    To get it on the road it first needed new tires. I didn’t want to just throw new tires on the 14 inch rims so I Got a cheap set of 18x7’s and 18x8’s as a temporary solution. The plan was to swap over to the large bolt pattern, front is an easy fix with new brakes but the rear was a problem with the small bolt pattern 7.25 rear so I used some adapters to get by. I liked the style but the rears didn’t fit properly but they worked to get the car drivable.
    Duster 1001 0000.jpg Duster 1002 000.jpg Duster 1003 000.jpg Duster 1004.jpg Duster 1005.jpg Duster 1006.jpg Duster 1007.jpg Duster 1008.jpg
  2. Red Stripe
    62
    75
    Jul 19, 2012
    Mountain View
    Local Time:
    9:31 PM
    Now it was suspension time, this is probably my favorite part to work on especially when adding nice new shiny parts. The main goal with the new parts was to make the car comfortable to drive and not a stiff race car feel but also something that is not going to get out handled by a minivan. I tore the whole front end apart and added QA1 upper control arms, QA1 strut rods, QA1 steering rods, hotchkis front sway bar, hotchkis/fox shocks, Dr. Diff cobra style 13” brakes, new master cylinder, brake lines, new pitman, idler arm, and lower control arm bushings. Also boxed the lower arms while they were off.
    I did add a set of 1.03 torsion bars but they made the car sit like a 4x4. No matter how I installed them (arm at full drop/ride height/and even up) I couldn’t get the car to sit properly so they came off and the stock slant six bars went back in for now. I think the clocking is wrong but I’ll get a proper set from Firm Feel eventually. I also have a set of Hotchkis subframe connectors that need to go in.
    Duster 1009.jpg Duster 1010.jpg Duster 1011.jpg Duster 1012.jpg Duster 1013.jpg Duster 1014 5.jpg Duster 1014.jpg Duster 1015.jpg Duster 1016.jpg
    • Like Like x 4
    • Red Stripe
      62
      75
      Jul 19, 2012
      Mountain View
      Local Time:
      9:31 PM
      Next was to clean up the engine bay. I did a compression test on the motor and it turned out to be in great shape so for now it is staying in the car. No smoke, no leaks, and it ran smooth. Had absolutely no power but it is kinda fun to work on. So, I started pulling off parts to clean up and paint. Removed all the a/c parts since they didn’t work and removed everything else that wasn't used to clean it up. I tried to match the color in the engine bay but it came out a little darker than expected but I can live with it. Painted the motor and intake while it was apart and the engine bay started looking sanitary.
      New gaskets all around, changed all fluids, adjusted the valves, cleaned up the carb, new valve cover, new ignition parts, and it was running smooth. The radiator fell apart while removing it so a new Champion aluminum radiator went in its place. Bummer here is the new radiator is a little thicker so the stock mechanical fan didn’t fit with the clutch. So I added an electric fan up front and it has been cooling nicely.
      • Like Like x 2
      • Red Stripe
        62
        75
        Jul 19, 2012
        Mountain View
        Local Time:
        9:31 PM
        Then I tackled the paint. A full repaint was out of the question so I wet sanded it first and then went to town with the DA polisher. Paint came out pretty good and brought some of the shine back. The problem is when I got it I painted the rear quarters to fix some bad paint. it looked fine when it was faded but once it was shined up you could really tell the paint doesn’t match. Eventually it will be corrected but for now it will be mismatched.
        Duster 1021.jpg Duster 1022.jpg Duster 1023.jpg Duster 1024.jpg Duster 1025.jpg Duster 1026.jpg
        • Like Like x 2
        • Red Stripe
          62
          75
          Jul 19, 2012
          Mountain View
          Local Time:
          9:31 PM
          The interior was a mess so everything came out and went and all new stuff went in. Seats, carpet, headliner, dash pad, steering wheel, door panels, stereo, dynamat all around and a bunch of other smaller parts went in. I didn’t see the point in recovering the bench seat so I went with a set of Corbeau Sport seats in leather for a more comfortable ride. And the rear seat got new foam and a cover from Legendary.
          Duster 1027.jpg Duster 1028.jpg Duster 1029.jpg Duster 1030.jpg Duster 1031.jpg Duster 1032.jpg Duster 1033.jpg Duster 1034.jpg Duster 1035.jpg Duster 1036.jpg
          • Like Like x 1
          • Red Stripe
            62
            75
            Jul 19, 2012
            Mountain View
            Local Time:
            9:31 PM
            More progress pics
            Duster 1037.jpg Duster 1038.jpg Duster 1039.jpg Duster 1040.jpg Duster 1041.jpg Duster 1042.jpg Duster 100026.jpg
            • Like Like x 2
            • Red Stripe
              62
              75
              Jul 19, 2012
              Mountain View
              Local Time:
              9:31 PM
              About six months later I decided I was done with the stock gauges and went with a set from Speedhut. I really like these gauges. You can pick any color combo you want and they are easy to install. I went with a grey/white set that light up blue at night. I like that you can set warning lights and the fuel gauge can be calibrated to any sender so no more issues with the repro sending units.
              Duster 1047.jpg Duster 1048.jpg Duster 1049.jpg Duster 1050.jpg Duster 1051.jpg Duster 1052.jpg Duster 100025.jpg
              • Like Like x 1
              • Red Stripe
                62
                75
                Jul 19, 2012
                Mountain View
                Local Time:
                9:31 PM
                I also knew I wanted a console with cupholders. The stock console aside from being expensive doesn’t really have the look I wanted. So I looked at newer cars and got a 2017 Challenger console and threw it in there. Fit almost perfect so I welded in some mounts and in it went. The only issue with it was the front of it housed the heater controls which I wasn’t using. So I filled in the area with ABS plastic and then mounted a clock, a/f gauge, and a trans temp gauge from Speedhut. These gauges are thin so they fit inside perfectly. I added in a Hurst shifter and made a cover so it looks right at home. Still need to pull the column and replace the collars so I can get rid of the column shift look.
                Duster 1063.jpg Duster 1064.jpg Duster 1065.jpg Duster 1066.jpg Duster 1067.jpg
                • Like Like x 4
                • Red Stripe
                  62
                  75
                  Jul 19, 2012
                  Mountain View
                  Local Time:
                  9:31 PM
                  As the new parts went in the old wiring was showing its faults. I installed an American Autowire kit in the Charger and really liked it so another kit from them was on order. With the kit I had to get a new one wire alternator but the install was smooth and everything worked out great. While working on the electrical I added all new LED lights all the way around, HID headlights, and swapped in a sharktooth grill.
                  Duster 1045.jpg Duster 1046.jpg Duster 1075.jpg Duster 1076.jpg Duster 1077.jpg Duster 1078.jpg Duster 1079.jpg Duster 100027.jpg
                  • Like Like x 2
                  • Red Stripe
                    62
                    75
                    Jul 19, 2012
                    Mountain View
                    Local Time:
                    9:31 PM
                    Then I started having carb issues. It was dumping gas into the engine and I couldn’t find rebuild kits for it. Rebuilt carbs were a couple hundred bucks so I decided to go with a 4 barrel carb so I could get replacement parts easily. With the new Quickfuel carb I had to get a new intake from Offenhauser and kickdown linkage from Bouchilon Performance. Carb is way to big but it did give the throttle response a much better feel. Also the repro mopar ignition module crapped out so I installed an MSD box I'd been holding onto.
                  • Red Stripe
                    62
                    75
                    Jul 19, 2012
                    Mountain View
                    Local Time:
                    9:31 PM
                    Next was the rear end. The 7.25 stock rear was garbage along with the leaf springs. So a new setup was built. Got a Sure Trac center section with 3.23 gears, axles, the housing, rear brakes, and brake lines from Dr. Diff. Cass has been great to work with and everything has been top notch. Also got a set of Hotchkis leaf springs and the new rear went in. Had a local shop build a new driveshaft and it all went in nice and easy.
                    Duster 1085.jpg Duster 1086.jpg Duster 1087.jpg Duster 1088.jpg Duster 1089.jpg Duster 1090.jpg Duster 1091.jpg Duster 1096.jpg
                  • Red Stripe
                    62
                    75
                    Jul 19, 2012
                    Mountain View
                    Local Time:
                    9:31 PM
                    Now that I had the rear end finished, I could order a wider set of wheels that fill out the back better. Duster’s have a huge lip on the rear so I trimmed about ½” and rolled the front lips to fit as much tire as possible.
                    Duster 1092.jpg Duster 1093.jpg Duster 1094.jpg Duster 1095.jpg Duster 1097.jpg Duster 1098.jpg Duster 1100.jpg Duster 1101.jpg
                    • Like Like x 2
                    • Red Stripe
                      62
                      75
                      Jul 19, 2012
                      Mountain View
                      Local Time:
                      9:31 PM
                      While the wheels were on order, I decided that I like being broke and replacing perfectly good parts so I bought a set of Viper calipers for the front. The car stopped fine but now should be on another level.
                      Duster 1105.jpg Duster 1106.jpg Duster 1107.jpg Duster 1108.jpg Duster 1109.jpg
                      • Like Like x 4
                      • Red Stripe
                        62
                        75
                        Jul 19, 2012
                        Mountain View
                        Local Time:
                        9:31 PM
                        Ended up fitting 18 x 9’s up front and 18 x 9.5’s out back with 275’s on all 4 corners. I’ve always liked trans am styled cars so I went with a mini lite style wheel from a local company here in the bay area called ET Mags.
                        • Like Like x 1
                        • Thanks! Thanks! x 1
                        • Red Stripe
                          62
                          75
                          Jul 19, 2012
                          Mountain View
                          Local Time:
                          9:31 PM
                          I still have a few things in the works but this is where it is at as of now. I have a new exhaust, rear sway bar, gas tank and lines, hoodscoop, and subframe connectors to install. I also need to have the quarters repainted. I can’t get a good match on my own so I need to take it to a shop to have it professionally done. I also have 2 sets of stripes, one is the stock solid stripe and the other is a Cuda T/A style stripe. Not sure which one but I’m leaning towards the T/A or AAR stripe which will go on after the paint gets fixed. The plan is to drive it as is for a couple years to save up and then take it to the next step... 408 stroker small block or 6.4 Hemi with side exit exhaust to complete the trans am look. Or Torquestorm has a supercharger kit for the slant six.
                          Thanks for checking out the build.
                          • Like Like x 3
                          • SSG_Karg
                            SSG_Karg Heeeeeres Johnny!
                            1,367
                            1240
                            Feb 24, 2010
                            In the pits
                            Local Time:
                            12:31 AM
                            VERY NICE! I’m soooo jealous that you found such a solid rust-free car to start with. Looking forward to future updates on this car.
                          • Scamp Rhonda
                            Scamp Rhonda Well-Known Member
                            434
                            385
                            Jan 18, 2017
                            Blaine MN
                            Local Time:
                            11:31 PM
                            Nice build. Great pictures. Love the 6 cylinder. It's cool being different. None stock fun! Steve
                          • Thomas Dennis
                            Thomas Dennis Well-Known Member
                            226
                            103
                            Oct 31, 2019
                            Hudson FL
                            Local Time:
                            12:31 AM
                            Very nice car
                          • Mtrhead
                            Mtrhead Ace of Spades ♠️
                            2,229
                            724
                            Sep 19, 2018
                            S.C.
                            Local Time:
                            12:31 AM
                          • 408 swinger
                            408 swinger FABO Gold Member FABO Gold Member
                            1,917
                            1666
                            Nov 12, 2010
                            Iowa
                            Local Time:
                            11:31 PM
                            Nice build! Love that the 6 didn't get 86'd right away. Good work! Keep it going!
                          • missing linc
                            missing linc Loose nut behind the wheel
                            2,198
                            3370
                            Feb 17, 2019
                            Southern Alberta Canada
                            Local Time:
                            10:31 PM
                            That is a really great looking car, love all the upgrades, will be a breeze when the 408 arrives!! Keeping the 6 is cool, not everyone would go that route. Nice work.
                            Really like the late model Challenger console, great idea, I've been considering alternatives to the original, as they are getting pricey.
                          • RustyRatRod
                            RustyRatRod Bla de blizhibliz de blatde blizi bla bla FABO Gold Member
                            65,786
                            39088
                            Jun 7, 2010
                            Georgia
                            Local Time:
                            12:31 AM
                            Really nice car! It's nice to get one that doesn't have a ton of rust. I liked the first wheels you had on it better, but it's yours and whatever you like is all that counts. Do you plan to leave the slant in it?
                            • Agree Agree x 1
                            • Johnny Dart
                              Johnny Dart Well-Known Member
                              7,986
                              2550
                              Nov 30, 2006
                              So Cal
                              Local Time:
                              9:31 PM
                              You do nice work...Hate to see it all go to waste. Time to shake the boat anchor.
                            • Divenut
                              Divenut Well-Known Member
                              3,150
                              1480
                              Sep 22, 2011
                              Naperville Illinois
                              Local Time:
                              11:31 PM
                              Love it! Nicely done.
                              Pat
                            • jonn6464
                              jonn6464 1970 Duster
                              527
                              382
                              Mar 29, 2017
                              Weatherford, TX
                              Local Time:
                              11:31 PM
                              Nice job Red Stripe. Great attention to detail and I like that you use quality parts. Better than having to do it again down the road!
                              Hey, the chin spoiler with the Plymouth logo is a great touch. Very small detail, but compliments the front end very well. Where did you get the spoiler?
