72 Scamp lenses rear & front
Enjoying it again
Ontario
Hello Everyone. Is there any aftermarket place to secure lenses for both front and rear signal lenses within the two bumpers as mine have faded. Thank you for your time, effort, and knowledge.
I believe a 72 Scamp has the same front lenses as a Duster. The rear lenses are the problem. You can get new 1970 Dart lenses and they fit and work fine, but the pattern cast into the lenses are different. Original Scamp lenses have a diamond pattern while Dart lenses have concentric circles. Only a rear A-body geek would pick it up but nobody repops the Scamp lenses
Thank you for the insight. Any used lenses that I have been able to locate have various problems, therefore, does anyone make replacement lenses? Thank you
Check with Laysons Restorations , Mega Parts USA, and Classic Industries
There are dozens of Mopar Parts suppliers that may have the lenses.
If you are looking for used lights here you will need to start a wanted thread in the classified forum.
thank you for the point in the right direction. Keep safe and God bless
Like toolman mike said you can get the 70 Dart tailights lots of places, but if you are doing a textbook restoration then you can see what the real Scamp lights go for (WOW!).
Yes the defib was required when the prices appeared. The other problem is that the Canadian 1972 model has dual lenses on each side of the licence plate which is different than the American model. Now that is one big caveat.
so it like a Dart then
