72 wing window removal
mechanic190
Rozet
Well I give up! I'm trying to strip my car down for primer and i'm very frustrated with the wing windows. I got the long bolt with the 1/4 inch bolt head on top off. The adjuster nut off the door jam, and screws for the weather stripping off. Am I missing something or am I not holding my tongue in the right position?
Did you get the one on the bottom of the door? There is a plastic plug on the bottom of the door with a nut hiding behind it.
On your door there is a small plastic plug at the base area of your wing window. You will need to remove it and insert an allen wrench to loosen the hidden bolt.
I know I didn't pull a plug. I'll look tomorrow but do I have to crawl under it and look up or just on the bottom facing the interior? And no allen headed bolt, are you guys talking about the same bolt?
