727 46RH conversion coming
Transmission and Drivetrain Tech
  1. 67dartgtgo
    67dartgtgo FABO Gold Member FABO Gold Member
    884
    281
    Nov 9, 2012
    Mass
    Local Time:
    1:48 PM
    Hi guys,
    I've decided to do it this fall and have a rebuilt A518/46RH to replace my 727 with. Going in a 1967 Dart. I've done lots of research and will start a thread and try to do a good documentation on it when I get there.
    I'll have some questions for the smart tranny guys.
    My first one is are the 67/68 single pole 727 neutral safety switches a direct swap with the 46RH 3 pole switch? or will I have to change the rooster comb? The reverse switch is located in the console shifter in this car.
  2. 67dartgtgo
    884
    281
    Nov 9, 2012
    Mass
    Local Time:
    1:48 PM
    Also can a valve body be removed while the transmission is standing on its end, tc end down on the bell, without losing anything or creating any issues or is it not recommended?
  3. TrailBeast
    TrailBeast Slightly Twisted Member
    20,429
    7342
    Mar 11, 2011
    Arizona
    Local Time:
    11:48 AM
    Single an 3 pole switches are not interchangable, but you might consider a neutral switch also in the console.
    I think it would be a lot simpler than changing the trans stuff.
    The valve body check balls are between the layers of the valve body and will not fall out from taking the VB off.
    The only loose thing when you pull the VB is the accumulator spring and it's real obvious.
    Yes you can pull the VB in any orientation without loosing anything.
    • Thanks! Thanks! x 1
    • Agree Agree x 1
    • jas0162
      jas0162 Well-Known Member
      466
      278
      Apr 23, 2014
      kansas
      Local Time:
      12:48 PM
      Just use the hook up your neutral switch wire to the middle wire on the 3 wire terminal.
      • Agree Agree x 1
      • 67dartgtgo
        884
        281
        Nov 9, 2012
        Mass
        Local Time:
        1:48 PM
        I wondered if it were possible to just use the center pole on the neutral safety but wasn’t sure if it’s been done. I was hoping the switches were interchangeable and would just lose the back up light circuit which I wouldn’t need anyway.
        • Agree Agree x 1
        • TrailBeast
          20,429
          7342
          Mar 11, 2011
          Arizona
          Local Time:
          11:48 AM
          You could do it that way.
          All the neutral safety function needs is a ground in neutral and park, and that's the center pole.
          Don't know why I didn't think of that the first go around.:D
          • 67dartgtgo
            884
            281
            Nov 9, 2012
            Mass
            Local Time:
            1:48 PM
            No worries at all trailbeast. I can just use the 3 pin pigtail and wire the center contact and be good to go.
          • 67dartgtgo
            884
            281
            Nov 9, 2012
            Mass
            Local Time:
            1:48 PM
            How can you tell if your valve body has a shift kit installed.
          • TrailBeast
            20,429
            7342
            Mar 11, 2011
            Arizona
            Local Time:
            11:48 AM
            Some kits have a different color separator plate for the valve body, but not all.
            I modded my factory plate, so even though it has a kit it still looks bone stock.
            You might take a look at the pressure regulator valve spring adjustment.
            Compare it's position to a non kitted pressure valve adjustment, because most kits instruct to change that quite a bit.
            If you can look up some of the kit instructions and see what they say about that might be a good idea.
            • HTRTrash
              HTRTrash Well-Known Member
              111
              3
              Feb 21, 2010
              Wylie, Tx
              Local Time:
              1:48 PM
              Any updates?
              • Like Like x 1
              • transman
                transman Well-Known Member
                747
                223
                Jun 17, 2007
                Western Canada
                Local Time:
                10:48 AM
                What kind of updates are you thinking of? There is a ton of updates done on that transmission, including a change in the overdrive planetary kit by the factory. There were issues with the early design 22.5-degree tooth pitch to the late design 15-degree tooth pitch. The early design was a weak design, hence the change by the factory.
                • kursplat
                  kursplat FABO Gold Member FABO Gold Member
                  2,067
                  1212
                  Aug 24, 2010
                  so cal
                  Local Time:
                  10:48 AM
                  thinking more like, did he get it done?
                  • Like Like x 1
                  • 67dartgtgo
                    884
                    281
                    Nov 9, 2012
                    Mass
                    Local Time:
                    1:48 PM
                    Any updates?
                    I’m getting ready to start the swap by the end of the month I think. I believe I’ve got all my parts but still get a little confused on the wiring with relays. Not my strongest suit. I may reach out to @TrailBeast for help with that as I like the way he wired his.
                    I’ve done a shift kit on the valve body, I have Hobbs pressure switches for the od/lu solenoids circuits and a vacuum interupt switch.
                    I’ve been replacing my front k member and suspension after rebuilding them so that’s taken some time. I also cut out my garbage headers and replaced them with trebligs manifolds.
                    I figure I’m not going to be driving this for a couple months anyway here in Massachusetts but have been reluctant to do the swap until the front end was done.
                    Thanks for asking and giving me motivation.
                  • 67dartgtgo
                    884
                    281
                    Nov 9, 2012
                    Mass
                    Local Time:
                    1:48 PM
                    I’m also following @MileHighDart with his installation thread and am really looking forward to seeing his finished. Some outstanding work there.
                    • Agree Agree x 2
