[WANTED] 727 column shift trans linkages
krazykuda
How-To Section Editor
Orland Park, IL
I am looking for the 727 transmission linkages for a column shift 71 Valiant... If you have a complete set, I would take them, but what I really need is the shift lever that goes on the transmission, and the linkage rod that goes from that trans lever to the z-bar...
Let me know what you have and how much you are asking....
This is what they look like...
those pieces usually can be adjusted even if they are from a 904.The transverse rod from the frame to the transmission with bell crank is the difficult one to find.For a 727 it is 1" shorter than a 904 because a 727 is wider.You can force a 904 piece in and it might work but it won't be right.
you can index and shorten one from a 904, just take the inch out of the middle.
the transmission bracket is different as well...or maybe you already have the correct parts.
