M_Body_Coupe
Do you still have a part# for that bushing?...I was going to have the yoke hard chromed to tighten it up, but ended up using a Teflon coated bushing from a GM or Ford or something that left it with the perfect clearance and no more high speed vibration...
I ask b/c last season I was trying to chase this thing down. Had a pronounced vibration at high speed, replaced the trans and rear-end yokes (the shop felt the roller bearings in the yokes were showing wear, was actually told by them: "...umm, just how hard do you yank on the yoke cap retaining u-bolts???...", they thought maybe the caps were being distorted and that actually caused the wear. I swear I was within spec...but that was done years ago and I had not written down any assembly notes, so we replaced with new parts.
Anyways...so I put everything back together and of course it made no sense to re-assemble with the old tailshaft bushing. Since I had the tool already I tossed in a NEW bushing.
The Durabond RP6189T had an oil capture coating on the inside that made it for a tighter fit, like 0.001", but it did not have the oiling hole, so instead I used the Timken 7300S bushing.
In the end, I had a couple of thousands less play, but the high speed vibration didn't change much, if at all, so I'm inclined to think that in my case it must be something else and having gone through just about all the other components I am only left with the 727 transmission internals.
