727 Identification and Tail housing swap
Transmission and Drivetrain Tech
  1. C2ndLTpigeon
    C2ndLTpigeon Mopar or no Car! FABO Gold Member
    567
    155
    May 18, 2019
    Indio California
    Local Time:
    7:49 AM
    Can someone help me identify this 727? The number on the side looks to be: PK3736145 4940 0717? I purchased this with a 360 that has an emission sticker of Feb 1975.
    I plan to put it in my 73 Valiant down the road. I know that I will have to swap the tail housing and output shaft which is no problem as I will be tearing down the complete unit and rebuilding it. What I wanted to know is Other than the output shaft, housing and maybe the governor, is there anything else I may need to change?
    173945090_1937168556460044_7608197690936659472_n.jpg 176687350_284428979986846_6537978471347032773_n.jpg
  2. fshd4it
    fshd4it Squid inc FABO Gold Member
    379
    154
    Jun 9, 2016
    Winock WA
    Local Time:
    7:49 AM
    That number comes up for '74-'75 318 or 360 powered D200/D300 truck.
    • Like Like x 1
    • jas0162
      jas0162 Well-Known Member
      596
      392
      Apr 23, 2014
      kansas
      Local Time:
      9:49 AM
      They changed the spline angle on the output shaft to gear set in the mid seventies. Make sure you get the right one as they do not interchange. I’m not sure exactly when they did it, but I think around 75.
    • C2ndLTpigeon
      567
      155
      May 18, 2019
      Indio California
      Local Time:
      7:49 AM
      From this post I found after doing some digging it looks like 76 was the year that the shaft changed.
      • Thanks! Thanks! x 1
      • 67Dart273
        67Dart273 FABO Gold Member FABO Gold Member
        49,653
        17971
        Oct 14, 2010
        Idaho
        Local Time:
        7:49 AM
        Actually you would NOT have to change anything......I've been told guys get a shaft made with a slip setup on/ in the shaft. Of course then it would be unique and more expensive, so you "might not" wanna..........
      • C2ndLTpigeon
        567
        155
        May 18, 2019
        Indio California
        Local Time:
        7:49 AM
        I've read that as well especially the spendy part. The one I got needs a tear down any way so I don't mind doing the swap.
      • whatsamerc??
        whatsamerc?? Active Member
        39
        1
        Dec 22, 2014
        butler al
        Local Time:
        9:49 AM
        Would you sell the yoke off your trans?
      • C2ndLTpigeon
        567
        155
        May 18, 2019
        Indio California
        Local Time:
        7:49 AM
        The bolt on yoke?
      • oldkimmer
        oldkimmer FABO Gold Member FABO Gold Member
        19,821
        6835
        Nov 11, 2006
        Kindersley, Saskatchewan,
        Local Time:
        9:49 AM
        He is talking about the other end of the shaft that has the snap ring groove in it. Kim
        • whatsamerc??
          39
          1
          Dec 22, 2014
          butler al
          Local Time:
          9:49 AM
          Yes, i believe it will bolt up to a big block trans and it uses a smalle u joint.
        • C2ndLTpigeon
          567
          155
          May 18, 2019
          Indio California
          Local Time:
          7:49 AM
          Sent you a PM
