I was doing some work under the car on my 727 and noticed something about the throttle pressure lever (kickdown lever on the transmission).
When removing the linkage and moving the lever by hand I don't need to apply any pressure at all to move it at first (moving it by hand towards the back of the car).
Only after moving it a bit I can feel something like a spring engaging and then when releasing it it moves it back some.
It feels like it is a bit of slack. Is this normal? Could it be that I need to adjust the kickdown band and that play will dissapear? I was gonna adjust the bands anyway. But this got me curious, and I'm new to working on transmissions. It's a 74-74 727 and when searching the serial it appears to also be called Hvy Duty.
Been doing some reading and what I have found is the band is initially adjusted to 72 inch/pounds and then backed off two full turns. Does this sound right? I doubt I'll be able to get a torque wrench up there on the side of the trans though.
Also, I'm suspecting I might have the wrong dipstick. What would you say is the oil capacity for a 727 with normal depth pan and a 10" converter? I think I might have been overfilling it.
Thanks!
Thanks!
