727 Leak need info !
NCmtnDWELLER
Cartoogechaye - NC
Ok im pretty sure my 727 in my 886 is leaking around where linkage rotates does a seal or o -ring exist in this area I never messed with a leak in this vicinity thanks Chris
Im sure repairing such will be an adventure
I've done them but never while the transmission was in the car.
You're right, its really crowded and tight around there!
...and quit calling me sir, it makes me feel old, lol. Just kidding, I am old. :BangHead:
Vehicle in question is a 886 Power Wagon ambulance and might have a little more room than a Abody so maybe its not to bad of an ordeal !
Make sure that you check the shaft carefully. I changed the pan, and the seal twice before I realized there was a small groove worn into the shaft. Almost undetectable. Had to replace that part.....Problem solved.
