1. Ww58_bandit
    Ww58_bandit Well-Known Member
    62
    37
    Aug 19, 2019
    Uk
    Local Time:
    6:22 PM
    Currently building a 493 stroked 440 and estimate will put out between 650-750bhp.
    I'm running a complete standard 727 currently with a csr shield. Will have a fti torque converter with 3800 stall rate with 440 source sfi flex plate. Car will be street strip use.
    I'm wounding what power a 727 can handle. Guessing will need modifying to handle power and if so what parts will needed. Want to keep an auto option valve bodie thow so can keep auto function for street us. Can you get a manual/auto reverse valve bodie?
    Many thanks
  2. Lefty71
    Lefty71 Well-Known Member
    244
    178
    Nov 7, 2013
    Ohio
    Local Time:
    1:22 PM
    There are shops ( Cope and A&A ) making 700hp plus 727's that include special input and output shafts, can easily go $7k plus. If you have a high dollar motor, there's no sense in trying to go low budget on the rest of the drivetrain! Doubt you can use/abuse the trans with that 700 horse when on the street anyway realistically, but you'll need the safety/security of a proper built trans when on the launch pad!
    • Like Like x 2
    • Syleng1
      Syleng1 Karma is real and Life is short... FABO Gold Member
      1,555
      1142
      Jul 5, 2005
      North Franklin, CT
      Local Time:
      1:22 PM
      Personally I’ve seen up-to 1000hp run thru a 727. Heavily modified of course.
      With a good trans shop and proper parts I’d be safe at 750hp all day long.
      Since the days of my youth and with today’s technology I would not quote you any parts outside information written by Chrysler in the old DCC engine and Chasis books. Get a copy of those and start there. They are a wealth of excellent proven information to start with.
      syleng1
    • famous bob
      famous bob mopar misfit FABO Gold Member
      16,684
      6435
      Aug 14, 2011
      okla
      Local Time:
      12:22 PM
      ABOUT THE SAME HERE , A QUALITY REBUILD W/ GOOD PARTS AND A LOW BAND APPLY WILL DO IT ---------NO LOW GEAR BURN-OUTS !.
      • Agree Agree x 1
      • Ww58_bandit
        62
        37
        Aug 19, 2019
        Uk
        Local Time:
        6:22 PM
        What parts are needed I have limited knowledge on auto box's and 0 on 727s
      • bcschief
        bcschief Well-Known Member
        536
        148
        Feb 23, 2010
        Crescent City Florida
        Local Time:
        1:22 PM
        A former coworker told me when AMC was looking for an automatic to put behind the 401 they went with the 727 because it was the only transmission at the time that could take a full throttle down shift behind the 401.
      • 383Scampman
        383Scampman Well-Known Member
        1,631
        843
        Nov 24, 2013
        New Hampshire
        Local Time:
        1:22 PM
        TSR racing or A&A transmissions have the parts you need . Do not cheap out here . Good luck
      • CudaFactHackJob
        CudaFactHackJob FABO Gold Member FABO Gold Member
        1,149
        398
        Mar 17, 2016
        Hemet, Ca.
        Local Time:
        12:22 PM
        The 426 hemi was actual around 600 hp, and they didn't have red eagle clutches and kevlar bands back then. Not to mention that narrow direct drum bushing and journal they were running at the time. Now there are even seven plate red eagle direct clutch packs for around a hundred bucks, and similar forward packs available. I wouldn't get too carried away with those low (for a 727) power levels.
      • Syleng1
        1,555
        1142
        Jul 5, 2005
        North Franklin, CT
        Local Time:
        1:22 PM
        Just to add to the “mystical” Hemi lore. Those hemi’s came with very little warranty if any.... kinda tells you Chrysler knew what they were doing putting a 727 behind those engines.
      • CudaFactHackJob
        1,149
        398
        Mar 17, 2016
        Hemet, Ca.
        Local Time:
        12:22 PM
        The hemi came with a modified 727. A five plate direct for one. At 71 years old, I was around when the 727 equipped hemis were tearing up the tracks. I never heard any complaints. Did you?
        Warranty.."if any"? There was 'zero' warranty on any street racers from any manufacturer, starting back with the 413 cross ram to the Ford Thunderbolt, etc.
        • Agree Agree x 1
        • Lefty71
          244
          178
          Nov 7, 2013
          Ohio
          Local Time:
          1:22 PM
          If you want to read about the unit you are gonna build first (very smart), pick up the 727 books put out by Carl Monroe or Tom Hand, or both. Very, very informative and inexpensive first start, IMO.
        • transman
          transman Well-Known Member
          790
          249
          Jun 17, 2007
          Western Canada
          Local Time:
          10:22 AM
          Sure there was: the "TAIL LIGHT WARRNTY":icon_fU:
        • CudaFactHackJob
          1,149
          398
          Mar 17, 2016
          Hemet, Ca.
          Local Time:
          12:22 PM
          I stand corrected...I shall now sit down..
