727 Rebuild recommendations
Transmission and Drivetrain Tech
  1. jgchemie
    jgchemie Well-Known Member
    60
    13
    Nov 2, 2020
    New Mexico
    Local Time:
    1:32 AM
    While my 1969 A108 van is being repainted and I'm waiting on engine parts, I have the stock 727 tranny sitting in my garage. It was parked for 14 years prior to me buying it. What are people's recommendations for it? Supposedly it ran before it was parked but everything is caked in dirt. Do I:
    A) Put it back into the van once the engine is back (building a 390 stroker from the 318 case and probably adding a 2,000 - 2,5000 stall torque converter) and then deal with any problems as they arise?
    or
    B) Rebuild it now while I'm waiting for the other parts to be shipped and assembled?
    If I decide to rebuild it, what kit should I go for? I see ATP Automotive kits for $91 to TCI kits for $290. I have a FSM for my van. What other information do I need? Special tools? Lastly, the rear tail for these vans is slightly different than most- are there any special seals in them I need to be aware of?
    Thanks!
    Joe
  2. 413
    413 Well-Known Member
    64
    66
    Nov 13, 2019
    NW USA
    Local Time:
    12:32 AM
    390 cube stroker with a used unknown trans could be trouble. Or it could work fine. The only different seal is for the rear yoke. Everything else is the same.
    Pull the pan and see what’s inside, is it clean or full of debris? How is the fluid? Burnt or new?
    EDIT. It is ABSOLUTELY a 727. If you don’t know what you are looking at then don’t call it a 904 or 653 or anything else for that matter.
    The seal? No, the special output seal is not going to be in any rebuild kit. You have to buy it separately.
    • Like Like x 1
    • attenuated
      attenuated Attenuated
      76
      22
      Aug 28, 2010
      Rio Rancho, NM
      Local Time:
      1:32 AM
      At first glance it looks like a 904, not a 727? Like 413 suggested, drop the pan and see what it looks like inside then determine if it needs gaskets & seals or a full rebuild.
    • CudaFactHackJob
      CudaFactHackJob FABO Gold Member FABO Gold Member
      1,562
      583
      Mar 17, 2016
      Hemet, Ca.
      Local Time:
      2:32 AM
      Take that pos apart. First pull in and out on the input shaft and measure the endplay.
    • Rmoore
      Rmoore Well-Known Member
      507
      348
      Nov 14, 2018
      Gun Barrel City, Texas
      Local Time:
      2:32 AM
      I really think it would be a no brainer here !! Now is the time to do it ! I’m not saying buying the TCI kit is the way to go ! But just remember you get what you pay for !! The TCI is a good kit !
      • Like Like x 1
      • jgchemie
        60
        13
        Nov 2, 2020
        New Mexico
        Local Time:
        1:32 AM
        Rebuilding now is definitely what I was leaning towards!
        So then back to my questions- do I need any special tools or literature besides the FSM? Does the TCI kit have the pieces for the tail on the A108 van?
        It's definitely a 727, or at least that is what the door plate says is in the van.
      • jgchemie
        60
        13
        Nov 2, 2020
        New Mexico
        Local Time:
        1:32 AM
        Here are the markings on the tranny.
        On the outside bell housing it reads 432-3
        Inside on the plate around the input shaft it reads 3416963 L-4
        Is there a decoder to confirm this is actually a 727 from 1969?
      • 66fyssh
        66fyssh Don't Stop Believin' FABO Gold Member
        5,982
        5351
        Jun 22, 2013
        Northwest GA
        Local Time:
        3:32 AM
        Get a copy of Carl Monroe or Tom Hand's book (or both)!
        That and a video that a member here shares.
        Using a book and the video, I built my first one last year.
        • Like Like x 1
        • jgchemie
          60
          13
          Nov 2, 2020
          New Mexico
          Local Time:
          1:32 AM
          Thanks!
          Just found Tom Hand's book.
          • Like Like x 1
          • VOETOM
            VOETOM Well-Known Member
            942
            368
            Jul 27, 2008
            KC, MO area
            Local Time:
            2:32 AM
            I built one of those a while back! Bushing was worn out so we water jet cut a new urethane rubber insert for it.
          • jgchemie
            60
            13
            Nov 2, 2020
            New Mexico
            Local Time:
            1:32 AM
          • CudaFactHackJob
            1,562
            583
            Mar 17, 2016
            Hemet, Ca.
            Local Time:
            2:32 AM
            Numbers mean very little on a 50 year old tranny. You wouldn't believe the different stuff put together I find in old automatics. That's why I love taking them apart; to see what some previous mechanic installed. Transmissions are like a box of chocolates...ya never know what you're going to find..Step one= measure end play.
          • jgchemie
            60
            13
            Nov 2, 2020
            New Mexico
            Local Time:
            1:32 AM
            Measured about 20 - 30 thousandths... very roughly with a caliper (0.5 - 0.75 mm).
          • CudaFactHackJob
            1,562
            583
            Mar 17, 2016
            Hemet, Ca.
            Local Time:
            2:32 AM
            That's very little for an old trans; it's still within factory specs. Tap it in with a hammer, then pull on it.
          • jgchemie
            60
            13
            Nov 2, 2020
            New Mexico
            Local Time:
            1:32 AM
            Just to confirm, you talking about the end play between the drive shaft and the fix part in this image? I measured again after tapping with the hammer and got about 35 - 40 thousandths. Again- very rough measurement with my caliper.
          • Tims 66 Cuda
            Tims 66 Cuda Mopar mid life crisis
            295
            155
            May 28, 2018
            Poquoson, Va
            Local Time:
            3:32 AM
            Yep, 727. Ive got one just like it that came out of a 73 camper van .Im rebuilding the 360 that came out with it.
            Tim
            • Like Like x 1
            • jgchemie
              60
              13
              Nov 2, 2020
              New Mexico
              Local Time:
              1:32 AM
              what rebuild kit are you using?
            • CudaFactHackJob
              1,562
              583
              Mar 17, 2016
              Hemet, Ca.
              Local Time:
              2:32 AM
              Yes, that is correct. Now squirt some oil around where the pump meets the case and remove the pump and front drums and band and struts.
            • CudaFactHackJob
              1,562
              583
              Mar 17, 2016
              Hemet, Ca.
              Local Time:
              2:32 AM
              The shaft will wobble side to side somewhat; no problem; it's centered by the converter.
            • jgchemie
              60
              13
              Nov 2, 2020
              New Mexico
              Local Time:
              1:32 AM
              I think this is becoming a weekend project, not something I do on Monday night when I have work tomorrow :)
              Also, I stupidly pulled the tranny without draining the oil so I need to do that before I create a huge mess!
            • CudaFactHackJob
              1,562
              583
              Mar 17, 2016
              Hemet, Ca.
              Local Time:
              2:32 AM
              More like three weekends.
              • Agree Agree x 1
              • jgchemie
                60
                13
                Nov 2, 2020
                New Mexico
                Local Time:
                1:32 AM
                want to come over and help?!!
              • CudaFactHackJob
                1,562
                583
                Mar 17, 2016
                Hemet, Ca.
                Local Time:
                2:32 AM
                Sure, soon's I catch my breath around here..
              • Tims 66 Cuda
                295
                155
                May 28, 2018
                Poquoson, Va
                Local Time:
                3:32 AM
                Rebuild kit for the tranny or the motor?
              • jgchemie
                60
                13
                Nov 2, 2020
                New Mexico
                Local Time:
                1:32 AM
                Tranny
