727 shifting into third slow
Transmission and Drivetrain Tech
  1. moparwedden
    moparwedden Well-Known Member
    797
    11
    Apr 13, 2006
    trenton,ontario,canada
    Local Time:
    8:21 AM
    Ok it's got a trans go shift kit. Bb 727. First is good. Second is good. Reverse is good. All hard shifts. Third basically just slides in but have to let off the gas so it goes in. Fluid looks good znd clean. Levels were fine also. Dropped pan and nothing in it.
    Before I pull tranny is there an adjustment I can do. Lokar cable is adjusted correctly.
    Thanks
    John
  2. TrailBeast
    TrailBeast Slightly Twisted Member
    20,779
    7933
    Mar 11, 2011
    Arizona
    Local Time:
    5:21 AM
    Maybe just pull the valve body and open up the 3rd gear oil supply hole in the separator plate.
    Have you adjusted the kickdown/2nd gear band yet?
    Might just be a big gap between 2nd and third.
  3. moparwedden
    797
    11
    Apr 13, 2006
    Local Time:
    8:21 AM
    Ok thanks I will try tgat
  4. AJ/FormS
    AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s
    17,591
    5988
    Jan 19, 2014
    South-Central Manitoba,Canada, 900ftelevation
    Local Time:
    7:21 AM
    Does the engine rev up a bit on the 2-3 shift?
  5. moparwedden
    797
    11
    Apr 13, 2006
    Local Time:
    8:21 AM
    Nothing noticeable.
  6. AJ/FormS
    17,591
    5988
    Jan 19, 2014
    Local Time:
    7:21 AM
    Is this problem there, just while manual shifting?
    IE;Has the governor pressure been eliminated?
  7. cannucky
    cannucky The Guy With No Birthday
    5,758
    673
    Sep 25, 2008
    Portage Du Fort QC
    Local Time:
    5:21 AM
    Maybe you just aren't making enough power to pull hard in third with all the weight in the cockpit ! Sorry couldn't resist Happy Birthday Buddy .
  8. TrailBeast
    20,779
    7933
    Mar 11, 2011
    Arizona
    Local Time:
    5:21 AM
    You know me, as I always go for alternatives when possible, but yes there are a lot of possibilities there and if one were just going to take it in anyway one wouldn't need to know all the possibilities.
    That's the way I was thinking about it anyway. :D
    I opted for a solve the specific problem fairly easy and pull it later when it really needed it method:D
  9. moparwedden
    797
    11
    Apr 13, 2006
    Local Time:
    8:21 AM
    road trip.lol
  10. oldkimmer
    oldkimmer FABO Gold Member FABO Gold Member
    14,092
    3489
    Nov 11, 2006
    Kindersley, Saskatchewan,
    Local Time:
    7:21 AM
    ...............is this a rebuilt trans or a used 1 with the kit installed............r u sure that u don't have severe overlap where 3rd is on way b4 2nd is released........who installed this kit..........does whomever comprendee the instructions.........kim........
  11. moparwedden
    797
    11
    Apr 13, 2006
    Local Time:
    8:21 AM
    Rebuilt trann
    new build
    Last year. No problems last year. New motor and put it back together. Took it to the track and started acting up on the way. I had it out for just some short runs around town and worked fine.
  12. AJ/FormS
    17,591
    5988
    Jan 19, 2014
    Local Time:
    7:21 AM
    Are you absolutely sure the oil level is correct? Yeah I read post #1,lol.
  13. moparwedden
    797
    11
    Apr 13, 2006
    Local Time:
    8:21 AM
    LOL yes very sure checked it twice, once cold and once hot. Levels were fine.
  14. AJ/FormS
    17,591
    5988
    Jan 19, 2014
    Local Time:
    7:21 AM
    On level ground and in Neutral
  15. downsr
    downsr FABO Gold Member FABO Gold Member
    873
    466
    Dec 17, 2011
    waverly ohio
    Local Time:
    7:21 AM
    Make sure your cable has not moved not letting it go all the way back on trans lever.I had the same thing.Had trans rebuilt last year started driving it this year and it slipped a little 2 to 3.Ended up band was burned up had to have it all redone AGAIN.Hope you have better luck than me
