727 Tranny Problems I Think
Transmission and Drivetrain Tech
  1. hoosierdaddy
    hoosierdaddy FABO Gold Member FABO Gold Member
    438
    195
    Nov 13, 2008
    Central Indiana
    Local Time:
    5:03 PM
    OK I installed a 727 tranny in my Duster that was suppose to good . I filled the tranny a few days ago and moved the car from the lift into the driveway no issues . I decided to do a shake down run around the block last night and the car wouldn't hardly move , I let it warm up a bit more and got to move in reverse back into the garage . I searched my problem on FABO and found the seals are probably hard and in need of a rebuild . So I ran home today at lunch , started the car and it firmly went into R & D(cold) . I come home tonight and raise the rear wheels off the ground and again the car goes into gear firmly and seems to have no problem . The reason I raised the rear wheels up I had the idea of trying make it shift but in reality it seemed like a bad idea . I'm just wondering if anyone has had this issue on a freshly filled tranny and yes it is filled to the proper level .
  2. famous bob
    famous bob mopar misfit FABO Gold Member
    13,156
    3820
    Aug 14, 2011
    okla
    Local Time:
    4:03 PM
    I never have, maybe the pump didn`t pick up like it should have / did u fill the convertor before installation ?
  3. hoosierdaddy
    438
    195
    Nov 13, 2008
    Central Indiana
    Local Time:
    5:03 PM
    If I remember I think I put a quart in the converter .
  4. George Jets
    George Jets 1967 Dart 2 Door FABO Gold Member
    572
    724
    Jan 18, 2019
    Farmington MN
    Local Time:
    4:03 PM
    Well you probably know all about this. The Mopar automatics have this thing called Morning Sickness where the pump needs to fill the torque converter before you take off. Torque Converter drain back usually causes this. The so called proper way on a cold start is to start the engine, then shift it into Neutral (the pump starts pumping in Neurtal and not in Park) let the engine and trans warm up a bit. The torque converter is now full and you are good to go.
    Some folks put a check valve in the outgoing side of the trans cooler line to the radiator to prevent the torque converter drain back. There is a kit from Trans Go that is supposed to help this drain back too.
    And Yes as you probably know, check the fluid idling in Neutral and not Park on the old Mopars.
    Hope this sheds some light on things for you . . .
    • Like Like x 2
    • hoosierdaddy
      438
      195
      Nov 13, 2008
      Central Indiana
      Local Time:
      5:03 PM
      Check the fluid in neutral you say , well color me stupid I didn't know that . Thanks
    • RedFish
      RedFish Well-Known Member
      23,426
      2243
      Sep 5, 2007
      Local Time:
      4:03 PM
      Read the dipstick, CHECK IDLING HOT IN NEUTRAL . We can get the same symptom from a worn trans if the pan is full of debris. It'll wok perfect cold/initially then start to slip more and more as filter collects to clogged. I forget if that diagnosis tip was Ford, GM, Chrysler, or all. Good luck with it.
    • lilfontleroy
      lilfontleroy annoyinglilLeRoy FABO Gold Member
      1,149
      949
      Nov 20, 2017
      USA
      Local Time:
      4:03 PM
      not only in neutral but with vehicle fully warmed up and sitting level
    • hoosierdaddy
      438
      195
      Nov 13, 2008
      Central Indiana
      Local Time:
      5:03 PM
      • Like Like x 1
      • hoosierdaddy
        438
        195
        Nov 13, 2008
        Central Indiana
        Local Time:
        5:03 PM
        I ended up being a pint low . I've done a little more driveway testing and all seems good so road time is the plan for the weekend . Thanks to everyone
      • George Jets
        572
        724
        Jan 18, 2019
        Farmington MN
        Local Time:
        4:03 PM
        Good Deal, Ready to Roll . . .
      • d55dave
        d55dave Well-Known Member
        2,382
        858
        May 20, 2010
        Kelowna, British Columbia
        Local Time:
        4:03 PM
        Do you have the tv (kickdown) linkage hooked up and properly adjusted?
      • George Jets
        572
        724
        Jan 18, 2019
        Farmington MN
        Local Time:
        4:03 PM
        Yes, pretty important too.
        There is a good youtube video on how to do it, by the old mopar techs of the 60s if you can find the video.
        Search: Mopar 727 kickdown adjust
        Good stuff there . . .
      • TrailBeast
        TrailBeast Slightly Twisted Member
        19,947
        6590
        Mar 11, 2011
        Arizona
        Local Time:
        2:03 PM
        It's also possible if that trans sat for awhile before it got put in something that the seals "took a set" and some warmup helped them flare back out and seal.
      • hoosierdaddy
        438
        195
        Nov 13, 2008
        Central Indiana
        Local Time:
        5:03 PM
        OK I'm back with a new problem , I went around the block and couldn't get the trans to shift out of 1st unless I did it manually and I never did get into 3rd . The trans I have was alledged to have been race prepped at one time , I did remove a mvb and install a known working automatic vb . I got into the governor last night and cleaned everything and reinstalled it but I didn't button up the tail shaft housing because I don't know if I have stock governor or race . I have a governor from a 904 thats different(appearance) from my 727 so I'm wondering if anyone can post a pic of a small block 727 governor . I realize this may tell me nothing but who knows .
      • oldkimmer
        oldkimmer FABO Gold Member FABO Gold Member
        11,439
        1846
        Nov 11, 2006
        Kindersley, Saskatchewan,
        Local Time:
        4:03 PM
        Probably only a factory governor. Kin
        • Thanks! Thanks! x 1
        • MoparLeo
          MoparLeo NRA PATRON LEVEL LIFE MEMBER
          436
          248
          Feb 10, 2016
          Moreno Valley, Cal. So. Cal.
          Local Time:
          2:03 PM
          Well...we started with a good transmission with the proper fluid level in the beginning of this thread and now we have a "race" prepped transmission with a manual valve body...Anything else we should know. Information is how you diagnose. Not guessing with partial info. George Jets was tactfully informing you how to properly check and fill the trans.
        • hoosierdaddy
          438
          195
          Nov 13, 2008
          Central Indiana
          Local Time:
          5:03 PM
          Sorry I missed your post post but I'm not sure of anything at this point . I'm using a Lokar style KD cable and I made several adjustments that did nothing to help the shifting , thats why I suspect the governor . Hopefully the governor was sticking since it was a little dirty(burnished looking) when I removed it .
        • hoosierdaddy
          438
          195
          Nov 13, 2008
          Central Indiana
          Local Time:
          5:03 PM
          Alright so I decided to take a big swing at the tranny since I've read and understand a tiny bit more . First off I reinstalled the original accumulator and MVB ,while I was in there I adjusted the front band . I took the car around the block and everything seems OK . When I was cleaning up my bench a ran across a rod about 3" long and it hit me it was a block rod for the accumulator which I didn't remember removing . So the next decision is whether to drain the tranny and install the rod or let it be .
        • oldkimmer
          11,439
          1846
          Nov 11, 2006
          Local Time:
          4:03 PM
          Without a spring or blocker rod in there the acc slams back and forth. The rod blocks it from moving and makes the 2nd gear shift firmer. The spring will cushion the impact. U could use almost any spring that will fit. Years ago the instructions said to leave the spring out. I have done many without the springs and have had no ill effects. Kim
        • hoosierdaddy
          438
          195
          Nov 13, 2008
          Central Indiana
          Local Time:
          5:03 PM
          I did install the spring so for now it works good and yes it shifts smooth into second .
        • oldkimmer
          11,439
          1846
          Nov 11, 2006
          Local Time:
          4:03 PM
          Then ur good to go. Kim
        • CudaFactHackJob
          CudaFactHackJob FABO Gold Member FABO Gold Member
          578
          190
          Mar 17, 2016
          Hemet, Ca.
          Local Time:
          4:03 PM
          If you had an engagement problem and cured it with just one pint of fluid, then it will probably rev between 2 and 3 at wot cuz it's still low.
