73 Duster 340
Space Duster
Austin, Tx
It's been awhile since I've posted anything. I'm working on this space duster. My son started a thread underI think under hookem.
Here's somemore pictures
Sprayed undercoating on the passenger side wheel well. Checking into someone to do some welding on the K member.
Working on fender today, going to take sometime.
After starting on it I think I'll look at getting another one. A lot of bondo.
Looks like the fender is covered with a thick layer of bondo.:blob::wack:
Pictures are not as clear as I hoped.
Worked fender and ttrunk lid today.:protest:
Worked on the passenger side fender today. I may be able to fix it and not have as much bondo on it. We will see.
I have been working on different parts of the car when I can. Did a little primer work too. I haven't had a lot of time to work on the car because, I've been working a lot of overtime.
Today I was working on get old undercoating off the driver's side front. Also, worked on the passenger fender.
I noticed today that the bottom door hinges installed differently. Trying to figure out which is correct.
