The title may be a bit misleading.
I have a 66 Coronet that I've converted the front brakes to a 73 Duster disk setup. It works, but I question weather I've done it correctly and humbly ask for clarification.
Everything I have, has come to me in pieces so I've never seen it all together.
I understand the "O ring", I believe. The metal retainer and the thin sheet metal pieces are my concern. I've seen images on the internet that shows the 90 degree bent edge, in the "up" position and also in the "down" position......I assume the correct direction is up ( please advise).
The thin sheet metal clips go on top or under the retainer bracket?
What is they're purpose?
Does anyone have a pic?
I'm almost ready to put a Kelsey Hayes setup in my 66 Barracuda, so I expect to be at the information "well" for that project in the near future .
Thank you
Thank you
