73 duster lower ball joints/knuckles
Suspension, Steering and Chassis
  1. charliec
    charliec FABO Gold Member FABO Gold Member
    165
    117
    Jun 13, 2017
    richmond texas
    Local Time:
    11:34 PM
    Obviously, the geometry has to be different on the left and right lower ball joints. But, I was surprised to see the different machining and dust covers on the two. The RH side has a much larger nest for the ball, a differently machined shoulder, and a different style dust cover. These are Moog parts (K783 LH and K781 RH). Is there a reason they are designed differently, or was it likely just a production thing in Moog?
  2. Murray
    Murray FABO Gold Member FABO Gold Member
    877
    457
    Apr 19, 2010
    San Jose, California
    Local Time:
    9:34 PM
    They should be the same construction, side to side. I understand that Moog is not as good as it used to be.
  3. MoparMike1974
    MoparMike1974 Well-Known Member
    1,033
    548
    Jun 16, 2017
    Maryland
    Local Time:
    12:34 AM
    Different production runs. Im sure they source many of their parts from other mfgs. The difference was they used to spec them and run tighter quality control but these days moog parts are hit or miss.
  4. charliec
    165
    117
    Jun 13, 2017
    richmond texas
    Local Time:
    11:34 PM
    kinda what I thought. No reason to think they won't work just fine. No one will ever see the difference once installed anyway. Just want function, not perfection.
