JAG_mopar
Experience Opinion requested. The car has been apart for several years. I replaced the tail panel AMD and fit the tail lights at the time with old bezels and old gaskets. I AM HAVING A HARD TIME WITH THE LIGHTS NOW. I used the Detroit muscle gaskets on the lights and NOS bezels. Not sure of which direction to go with hacking up something I don’t want to.
So the lights fit the bezel into the panel. Is the gaskets too dense? I can’t get the lights and bezel to compress enough to catch the nuts.
I also do not remember where the gasket seats on the quarter panel edge. Are Detroit gaskets too dense? Are the lighs supposed to overlap the hole? Was the AMD light hole too wide for the lamp to sit flush?
Maybe I should trim the gasket a little on the inner edge to allow it to sit without catching the lip of the panel?
I Added a picture of the line me where the hole meets the gasket.
Maybe you can see in the pictures?
I am trying the trim inside of the gasket trick.
