1. 1972trucks
    1972trucks Well-Known Member
    48
    5
    Sep 7, 2013
    Indiana
    Local Time:
    11:26 PM
    I have a 73 Duster that I got as a restoration project. It was a 6 cylinder car that the guy I got it from had already put a built 318 w/904 in it. He changed the K frame. I restored the body and am now to the point of trying to start it. I am about ready to try to start it so I put a new battery in it to see if the lights and the dash work but I have nothing . No power to anything. I have 12+ volts at the battery, 12+ at the hot wire wiring hookup on the fender well, 12+ at the bulkhead on the firewall, the starter is brand new and connected. II can't figure it out. Any thoughts or suggestions before I haul it off to an auto electric shop?
    • Like Like x 1
    • j par
      j par Well-hung Member
      14,333
      6765
      Jul 2, 2014
      Portland Oregon
      Local Time:
      8:26 PM
      My thoughts are this could be the turning point. If you start taking it to shops now you might as well just keep your wallet open.
      You're saying when you hit the starter part it's not turning over?
      • Agree Agree x 1
      • rumblefish360
        rumblefish360 All hail, "Kingwillrun" or be scorned by him
        35,222
        7156
        Jun 21, 2005
        New York, on a Island
        Local Time:
        11:26 PM
        How about after the bulkhead to the ignition switch?
      • Loggato
        Loggato Well-Known Member
        57
        79
        May 28, 2019
        Central Kansas
        Local Time:
        10:26 PM
        Check the two wires behind the ammeter on the gauge cluster. If they are not screwed into the gauge cluster nothing will work.
      • 1972trucks
        48
        5
        Sep 7, 2013
        Indiana
        Local Time:
        11:26 PM
        Haven't checked the wires on the cabin side of the bulkhead yet. The red and black are hooked up. I just put this dash cluster in . It was one I had that was in good shape. I am assuming it works. I have nothing period. No electrical at all
      • Demonic
        Demonic Well-Known Member
        511
        292
        Mar 21, 2015
        Maryland
        Local Time:
        11:26 PM
        One side on the ammeter is directly from the bulkhead connector. One of the two buss bars in the fuse box should be hot if the bulkhead connection is OK.
      • 1972trucks
        48
        5
        Sep 7, 2013
        Indiana
        Local Time:
        11:26 PM
        Thanks I will check this out tomorrow and post what I find
