Steve Agrella
Will going with drilled and slotted rotors make much of difference over the stock rotors using the stock calipers
None, zero, zip, unless your racing. There designed to stay cooler in the heat of competition. Rush hour traffic does seem like so but it is not nor is having fun with your buddies. Just don’t say, “Hey! Watch this ****!” And you’ll be fine. (LMAO!)Will going with drilled and slotted rotors make much of difference over the stock rotors using the stock calipers
I own two Mazda’s, one is a Mazda 6 Grand Touring the other is a Mazda 3, changed both cars to drilled and slotted rotors and green pads, the difference is night and day from the OEM pafs.
The reason that I did this on both cars was because of the stop and go traffic in California is a nightmare,.
Both cars were suffering from warped rotors from the heat, after the change which was maybe close to a year no more warped rotors and the cars stop on a dime.
The rotors I used were same as stock dia, the brake feel and the stopping power of the new setup really is quite amazing.
