74 Duster advice please on raising rear 2 in
Suspension, Steering and Chassis
  1. Steve Agrella
    Steve Agrella FABO Gold Member FABO Gold Member
    340
    76
    May 4, 2018
    Mission Hills Ca
    Local Time:
    10:12 PM
    My car is sagging in the rear had the front raised 1 inch because my headers were hitting the road.
    Don’t want shackles or air shocks can any anyone suggest how to raise the rear and wher to get parts on the cheap, thanks
  2. 72bluNblu
    72bluNblu FABO Gold Member FABO Gold Member
    9,040
    3015
    Nov 28, 2008
    NorCal
    Local Time:
    10:12 PM
    You can add a leaf spring to the current spring packs, have the springs re-curved by a spring shop, or buy new springs. Those are pretty much your options if you take air shocks and lift shackles off the table, which you're right in doing as those are just temporary band aids that will damage your car in the long run.
    The problem with adding a leaf is that you're upping the spring rate too, so you may not like how the car rides. How much you add to the rate depends on the length and thickness of the leaf you add, and where in the pack you add it, so your results can vary. Re-curving is good if you have a spring shop local to you that will do it, but how long it works can vary. They're old springs after all. New springs are by far the best way to go, but, also the most expensive. ESPO (springs n things) sells good quality leaf springs at pretty decent prices. They also sell springs with different arches to them, ie, +1", +2" etc. If you go that route, remember that your current springs have sagged, so, you probably don't want +2" springs, as they'll likely lift the car 3" or 4" from where it actually sits now. You probably just want stock or +1" springs.
  3. Lee Robinson
    Lee Robinson FABO Gold Member FABO Gold Member
    5,738
    179
    Aug 23, 2009
    El Dorado Hills, Ca.
    Local Time:
    12:12 AM
    Check General Spring. I have a 64 Fairlane, I got their stock rear springs for it. Raised rear of car 1.5-2 ". They had another spring choice that would raise it 2.75 ".
    They may have the same option for Mopar. I believe the springs with polyurethane bushings included were about $140.00 each.
  4. teringer
    teringer ase master hall of fame
    720
    118
    Feb 22, 2011
    kenly nc
    Local Time:
    12:12 AM
    go to a spring shop and buy just the main leafs and get two new center bolts , cut the eyes off the old main leafs install the new main leaves over the old modified ones and if you still have funds have them reached this is the cheapest way . 2 leafs and 2 bolts have done it when I as younger and funds were tight
  5. 72bluNblu
    9,040
    3015
    Nov 28, 2008
    NorCal
    Local Time:
    10:12 PM
    Right, that will work, but as I said before you've increased the spring rate by doing that.
    The spring rate of the old springs doesn't change as they age, just the arch. So the ride height changes as the springs sag, but the spring rate stays the same. Increasing the rear spring rate from stock is ok to a point, but if you add too much the car won't ride well. And just adding leafs you don't have a good idea of what you're doing to the spring rate.
  6. Steve Agrella
    340
    76
    May 4, 2018
    Mission Hills Ca
    Local Time:
    10:12 PM
    Going to take it to a spring guy out here that makes springs, he’s been doing it for 40 years said he can build me a new set of springs for $450 installed
  7. sireland67
    sireland67 Well-Known Member
    7,570
    1541
    Oct 27, 2010
    WV
    Local Time:
    1:12 AM
  8. Steve Agrella
    340
    76
    May 4, 2018
    Mission Hills Ca
    Local Time:
    10:12 PM
  9. sireland67
    7,570
    1541
    Oct 27, 2010
    WV
    Local Time:
    1:12 AM
    Stock 15” x 7” 4.25” back space
    275-60R-15 tire.
    I did put a 1” block in to lower the car.
  10. sireland67
    7,570
    1541
    Oct 27, 2010
    WV
    Local Time:
    1:12 AM
  11. Steve Agrella
    340
    76
    May 4, 2018
    Mission Hills Ca
    Local Time:
    10:12 PM
    The 275 fits in the stock wheel well, that like 10 ins wide with no problems.
    I just ordered crager 15 x 8
    thats looks great thanks for taking the time to share that with me
  12. sireland67
    7,570
    1541
    Oct 27, 2010
    WV
    Local Time:
    1:12 AM
    Crager's have a goofy backspace for mopars.
    My guess with those, you will hit the outer 1/4 panels.
    • Like Like x 1
    • Steve Agrella
      340
      76
      May 4, 2018
      Mission Hills Ca
      Local Time:
      10:12 PM
      Backspace is 4.125 only 1/8 shorter than yours
    • KENTON
      KENTON Well-Known Member
      599
      73
      Oct 2, 2013
      The Chicken Coop
      Local Time:
      11:12 PM
    • toolmanmike
      toolmanmike FABO Staff Staff Member FABO Gold Member
      35,280
      17238
      Jan 18, 2006
      Iowa
      Local Time:
      12:12 AM
      • Agree Agree x 1
      • Dusterdenovo
        Dusterdenovo Contentedly Old School FABO Gold Member
        800
        1306
        Dec 10, 2011
        British Columbia
        Local Time:
        10:12 PM
        Call ESPO and talk to Laura. She knows everything about springs for old Mopars. Seriously.
        • Agree Agree x 1
        • rumblefish360
          rumblefish360 so close yet so far away
          33,457
          5525
          Jun 21, 2005
          New York, on a Island
          Local Time:
          1:12 AM
          THIS! ^^^^^^
          THIS!!!!! ^^^^^^^^^^
          • Agree Agree x 1
