74 .Spool mounts for Magnum
Mojoe9955
NJ
Have a 70 slant 6 K member.
I'm swapping in a Magnum. Of course for the 6, I would need some conversion mounts.
I have access to a 74 V8 spool mount K member. Which way to go?
You did not say if your Magnum is a 5.2 or 5.9 size but either way I would just use conversion mounts from Schumacher Creative Services because it is the easiest way. Just choose the correct one for your engine size and note that Magnums are not listed because it has the same engine mount ears on the block as the LA engines.
'67-72 A-Body Slant 6 to 273/318 or 340/360
I have a 5.2. With the spool K I'll need come up with some spool mounts.
Probably as much as the conversion mounts, not to mention the extra 6 K member laying around.
Thanks Bob
Swap the k. It's what? Ten or twelve bolts?
I've done it with the motor in the car, and I'm a chump.
