75 Dart Swinger
Well I finally did something that adds to the visual appeal of the car! I ended up getting aero racing front rims and basset rears! Basset didn't have the right offset in a 7 inch for the front and Aero didn't have the right offset in an eight for the back so a compromise was made! They're the same style rim and the only difference is the pinstripe and the sticker. I like it though! I wrapped them in some Cooper Cobras Radial Gt's. 235/60/15's in the front and 255/60/15's in the back!
Here I shaved the auto column to look like a manual one!(I didn't take a picture before I started so I tooke one of my parts Duster with the same column) I think it looks way more cleaned up now! I also got some Tmi pro series low back seats, I haven't taken a picture of but I do love the way feel! I would recommend them for sure!
So it's been quite a while since I've posted apparently! Quite a bit has gotten done but since I'm Canadian the exchange rate has kind of put me off buying parts for now!:canada: I got some TMI low backs that I really like! And I got some mexican blankets for the back seat that I also like! Lol:lol:
The dart went to my buddy's place to get some body work and primer! The body is by no means perfect but right now it's good enough for me!
The little I did drive the car last year I noticed the transmission was making quite a bit of noise so I took it apart and replaced the synchros, counter shaft, cluster gear, and input shaft! It went fairly smooth for my first time rebuilding a transmission!
I was also tired of looking at the underbite of a bumper that is the 1975 dodge dart so I decided to change it! I didn't take any pictures of the process but I pretty much cut through both tubes for the 5mph bumper, then I split and took out the small piece of inner pipe that was left inside the larger one from the cut, then I shined up both pieces so the so it was a slip fit and remounted the bumper, tucked it close and welded it in place! I also took some weight out of the front bumper!
I apparently spent too much time in the gen 3 Hemi swap part of fabo and decided it was a good idea to Hemi swap the dart! The 360 wasn't running great, (most of the lifters wouldn't pump up) and I probably should've just change the cam and lifters but I wanted a Hemi so on the hunt I was! I found someone who wanted to buy the 360 for 750$ and then I found a eagle gen 3 for 100 bucks! So in one trip I sold one engine and bought another!
I had done quite a bit of research and what the guy was telling me lined up with what I was reading about the gen 3 wanting to flatten cams and when I pulled it apart it turned out I was right! What I didn't bank on was the PO never doing an oil change! :mad: the pistons had about half the degree of movement on the rod that they should! All in all it's still a good score for the price but now I was left without an engine for the dart!
So I decided to finally finish the 400 I started talking rebuilding a while ago because I thought that would be the most cost effective way to get the dart on the road this summer! It's a stock stroke, stock heads with .30 over Kieth black hypers and a Edelbrock performer air gap and I plan to buy a brawler 750 for it! I really put the carriage before the horse on this one and started building before learning about the aftermarket stroker support for these things! I wasted some money getting the old parts in usable condition but I'm sure that happens to most people getting into cars! Like I said in the previous post though I'm at a bit of a stand still because of the crappy Canadian dollar but hopefully this thing will burn some rubber this year!
Since I was putting the big block in I wanted to do the DC K frame conversion! (I didn't really want to but since Schumacher isn't making mounts I've got to take matters into my own hands! Lol here are some things I found along the way! I'm no expert but I think that's supposed to be inside the LCA a little more! :lol:
and this sleeve shouldn't be removable! It had been that way for a while but the looks of how whollered out the hole is!
Here's a prime example of someone before me who didn't have a Cotter pin but needed to pick up the kids in half an hour! :lol:
I put the k frame upside down on the table and put some nuts under all the mounting points to clear the table and
because I thought that would give me the best frame of reference to be able to pull measurements of the other pivot that wasn't broken!
surprisingly I was able to fill the gap that had been made from the pivot rubbing really well! I felt confident it was a strong weld with good penetration!
and while I was here I decided to take some big washers and reinforce the pivots as well! It worked better than I expected and turned out good for my welding experience or lack of!
I think I'm all caught up now! I've still got to move the motor mounts so that will happen in the next little while!
So it's been a while but things have still been happening! Since everything was out this was the perfect time to paint my engine bay! And yes I know Mopars never had anything but body color engine bays! But Having a white engine bay just seemed like too much work! Lol
I also got some B body headers for that are supposed to work with only some minor dings so we'll see how that goes!
I wasn't very confident in my cylinder heads so I ended up taking them back off and brought them to a machine shop! I'm glad I did because he basically told me they were garbage! One valve was very sunken in where somebody just did a valve job instead of installing a new seat! He priced out the machine work to make them serviceable and I decided instead of spending money into these heavy things I'll just go with some aluminum heads! So I ordered a pair of marsh performance sidewinder cylinder heads! I don't have them yet but hopefully next week! :)
I also bought some suspension parts from Bergman auto craft and he is a great guy to deal with! I bought the stage 1 suspension kit he offers and they accidentally sent me the camber bolt kit instead of the offset bushing kit! So I sent them a message saying what happened and that I could pay for the camber kit because I needed it anyway but he said that wasn't necessary and sent me the bushings free of charge!!
And after being completely overwhelmed with the radiator conversations that go on in Fabo I finally picked a cold case radiator! This is kind of a budget build so I was leaning towards the champion but the more I read I felt safer going with a cold case. I really don't want to have overheating issues with this thing so I decided to spend a bit more! I'll make sure to get some pictures of the rad and heads when they get here! I also was looking for a big block 4 speed bellhousing and was not having much luck until one day I found a lakewood 2 piece out in Grand Prairie Alberta and he was willing to ship it! I made up a block saver plate because it didn't come with one and it turned out great! I'm just waiting on some offset dowels to get my bellhousing concentric!
