zpsull01
I need to replace a major portion of the passenger side floor pan. Ideally a half pan that replaces that whole side is what I would use. Problem is, they don’t seem to exist.
1. Are the whole pans not offered for the 75-76 Valiants and Darts due to the additional catalytic converter clearance hump on the driver side? Was there any other changes to the passenger side pans in these years?
2. Would an early 70’s Dart passenger side pan work for my 75 Valiant, assuming the converter changes only affected the drivers side? I have measured the pan out against 2 of my Dusters and the only difference I can see is the 3” shorter rear section due to the 108” vs 111” wheelbase.
Thanks,
Zack
Thanks,
Zack
