[SOLD] 76 Aspen Rotors
RAT ROD AL
MOPAR ARCHAEOLOGIST - one parts hoard at a time!
Robbinsville, North Carolina
I have a pair of front disc hubs and rotors, complete with bearings. Big Bolt Pattern. All in good useable condition. $20 + the ride from FL. Paypal
Sorry Al it only showed your last reply. The 73-76 A body disc brake rotor also fits 76-89 FMJ bodies. Upgrade your 74 duster rear drums to 10x2.5" setup from an M body diplomat, fury, fifth ave to go with these in the front.
I have no idea why i mentioned rear brakes. Is there just one size of front brake rotors on all these models? Like these rotors would for sure fit my 74 a body duster? Sorry @moparmat2000
Does your 74 have factory equipped disc brakes with single piston slider calipers on the front? If the answer is yes, then these will fit your car. If it's a 74 duster with the factory discs on the front
If it is, then the rears should already be 10x2.5" drums. You can enhance the rear brake drum cooling by using the finned heavy duty drums off any RWD 84-89 diplomat, fury, or fifth ave
