76 Duster + 416 Stroker 340 + 4 Sp O/D A-833 ( Abody Trans ) + Misc Parts
Mopar Automobiles For Sale
Thread Status:
  1. MoparDon
    MoparDon New Member
    1
    0
    Aug 22, 2008
    Local Time:
    1:33 AM
    Contact Seller
    Bellingham MA 02019
    I’m Having An – “ I Just Got Married Sale “--lol
    The Real Reason for the Sale - Is so I can do my 65 Scooby Doo Van LOL
    MOPAR - 416 Stroker 340 Engine Assembly - A-Body A-833 O/D 4-Sp - Must Read - $5500
    340 Block (1969) Painted Orange – Bored .030 Over – Lifter Valler Deburred and Painted with Three Coats of Glyptal -
    MOPAR Cast Stroker Crank – Comes with Stock Damper – I Have an Externally Balanced BHJ Race Damper ( NEW )
    Available for a Few Dollars More – ( Rotating Assembly Externally Balanced in the FRONT and Neutrally Balanced in
    the REAR – EAGLE "H" - Beam Rods – DIAMOND Hypereutectic Pistons & Full Float Pins ( no pin locks ) DIAMOND
    1/16 Moly Race Rings – CLEVITE + Rod + Main + Cam Bearings ( Cam Bearings Installed – Original Main Cap Bolts –
    MELLING High Preasure / High Volume Oil Pump– MR GASKET Remote Oil Filter Relocation Kit With Installation
    Bracket - MOROSO Deep Oil Pickup + Tube + Screen ( modified for the stroker assembly ) MOROSO Deep Sump
    Oil Pan ( color black ) – CLOYES Double Roller Timing Chain - FEL-PRO Gaskets – 1008 Head / 1213 Intake / 1413
    Exhaust – MOPAR Valve Cover Gasket Set p/n 5429551 / Has Metal Securing Ring Molded in the Rubber –
    EDLEBROCK Aluminum Heads #6077 Closed Chambered with Stock Valves – ARP Head Bolts – COMP CAMS
    Titanium Retainers – COMP CAMS Valve Springs ( Outer – Inner – Damper ) – CRANE CAMS Gold Roller Rockers –
    MOPAR Chrome Rocker Shafts – LUNATI Custom Length Push Rods ( custom for this application only ) – COMP CAMS
    Mechanical Cam 244 – 250 Degrees @ .050 Lift - .540 - .556 Lift ( was in my 360 for 2 weeks, was a bit much ) COMP CAMS
    New Lifters – EDLEBROCK EPS 800 Carb ( also was on my 360 for 2 weeks ) – EDLEBROCK Aluminum Intake ( NEW Not Used)
    – MOPAR Chrome Ignition Box ( RACE ) or the Orange Box if Desired – MOPAR Recurved Distributor – NEW Alternator –
    NEW Mini Starter ( starter was in my 360 for a few weeks also - changed to full size starter ) No Exhaust – No Radiator -
    NO Valve Covers - Comes With 10 ¾” - 11" Machined/Turned Fly Wheel – Engine Is Disassembled.
    $ 4700 Firm
    MOPAR A-833 OVER/DRIVE A-Body 4 Speed ( YES -- OVER / DRIVE w/A-Body Tail Shaft ) – With an E-Body Aluminum V-8
    Over Drive Bell Housing ( to accommodate the larger nose cone for the over drive trans ) – 68 Dart 4 Speed Pedals – 68 Dart Z-Bar
    – And Some Misc Bars And Linkage.
    $ 600 Firm
    68 Dart 3 Speed Steering Column – 68 Dart Manual Steering Box – A-BODY 6 LEAVE Leaf Springs ( non super stock – just heavy duty )
    + Plus a Few Other Misc Parts -
    $ 200 Firm
    TOTAL ALL ABOVE $ 5500
    1976 DUSTER
    Runs + Drives + Stops - GREAT – But Does Need Work –
    Red Body and Black Roof ( ½ Vinyl Roof – Vinyl is Removed ) Black Interior -
    93.000 Original Miles - Slant 6 - Auto - Sm Bolt Pattern with HEAVY DUTY FRONT DRUM Brakes
    (( NOT DISC )) - Canadian Built - According to Galian Govier it was a Sales Bank Car that
    Must Have Used Up Existing Parts Therefore Could Possibly Explain the Drum Brakes )
    AFTER MARKET - 15 x 8 Rear and 14 x 7 Front Rallye Rims - Center Caps Not the Best -
    New After Market Trim Rings - 3rd Owner - First 2 Owners from Tolland CT.
    ( Mother and Daughter ) Will Give Purchaser the Original Owner Information
    $ 2700 Firm ( Car Only )
    KNOWN PROBLEMS
    Glove Box Lock Falls Out
    Speedo Acts Up for the First 15 Min Until Warm
    Windseild Has Quarter Size Crack, Drivers Side
    External Door Handles Are Sticky
    Minor Under Hood Rot On Pass Side About 10x10 Inches
    Hood Opener ( Pull Cable ) Has Been Relocated Outside
    Gas Guage INOP - 15 Miles to the Gallon is How I Measure It
    Front Seat Is Slightly Ripped
    Dash Pad Cracked
    Vinyl Roof Has Been Removed - And Painted Black
    Tail Pipe Needed ( after the muffler )
    Intake and Exhaust Gasket is Needed
    Horn Relay is Needed
    NEW PARTS
    New Tires / Custom Rims 15x8 Rear - 14x7 Front - Small Bolt
    New Trim Rings - Used Center Caps - New Fuel Filter - Starter -
    Water Pump - Battery
    ENG $ 5500 + CAR $ 2700 = $ 8200 >>> Will Sell Both for $ 7000 As a Pair
    However The price On The Car If Sold Seperate Is 2700 FIRM
    DON
    Bellingham MA 02019
    PM ME FOR TONS OF PIX
  2. cudacrazy67
    cudacrazy67 Well-Known Member
    1,384
    14
    Sep 20, 2008
    central,pa
    Local Time:
    2:33 AM
    Your ad will be deleted very soon. You need to read and understand rules before you post.
  3. 74DartSwinger360
    74DartSwinger360 The Brat Pack
    4,650
    113
    Apr 16, 2012
    Valrico, Florida
    Local Time:
    2:33 AM
    The thread is from september of 08
  4. inkjunkie
    inkjunkie Well-Known Member
    17,182
    2454
    May 24, 2009
    Local Time:
    11:33 PM
    talk about waking up the dead.....
  5. chooch
    chooch Well-Known Member
    95
    5
    Aug 5, 2010
    pixburgh,pa 15227
    Local Time:
    1:33 AM
    rutro scooby doo needs to learn how to read!!!:eek:ops:
Thread Status:
