C2ndLTpigeon
Mopar or no Car!
Looking to see if someone can point me to a good affordable overhaul kit for a 73 8 1/4?
I purchased the one that was from SKF on Rockauto and after doing some research it turns out a member on here in 2019 pointed out that the bearings were bigger for the axles and he was correct so I sent that one back. Just looking for one that is for a 73 and includes bolts shims etc.
Im planing on swapping this rear in my 73 Valiant from a 7 1/4 to a 8 1/4 that has a 318 with a 904 transmission. The drive shaft will need to be shortened and from what I could find it looks like it needs to be 1.5 inches shorter? Is this correct?
Thanks!
Thanks!
