Slantsix64
i know the 8.25 rearend swap into a 7 1/4 requires a cut in the drive shaft which is about 1.25. I have the original drive shaft which is a ball and trunion the drive shaft can be pushed in some what, I'm not sure how much it it will go in. being able can I just push it in 1.25 and run that rearend? Or would I need to cut that bad boy.
