1. haybag
    haybag Well-Known Member
    187
    17
    Dec 14, 2014
    New Hampshire
    Local Time:
    8:41 PM
    Found an abody 8.25 rear I am interested in buying to upgrade the 7.25 in my 71 Duster. Seller says it's a sure grip and has a 2.71 tag on it. If I buy it I would eventually want to put 3.55 gears in it. I have seen that there are 2 different rears , but only one will accept the higher numerical gears. thought I had read it was 2.76 . Can anyone confirm or deny if this rear with 2.71 can be upgraded to 3.55"s ? Thanks
  2. Slantsix64
    Slantsix64 Well-Known Member
    2,230
    826
    May 11, 2014
    SGV
    Local Time:
    7:41 PM
    Yup can upgrade to any ratio
  3. robert flippo
    robert flippo Well-Known Member
    213
    125
    May 9, 2018
    gibson station va
    Local Time:
    8:41 PM
    just finished changing a 271 to a 355 on my 74 duster, had a little problem getting old pinion out , but other than that, no problem.
  4. haybag
    187
    17
    Dec 14, 2014
    New Hampshire
    Local Time:
    8:41 PM
    Thanks for the responses, just wanted to make sure I wasn't setting myself up for problems.
  5. halifaxhops
    halifaxhops It's going to get stupid around here! FABO Gold Member
    57,311
    25285
    Jan 20, 2014
    CENTRURAL, PA
    Local Time:
    6:26 AM
    Your good its the 2.45 rears you cannot do it to.
    lots of info here.
    The 8 1/4 thread
    • Like Like x 1
    • Agree Agree x 1
    • lemondana
      lemondana BlackDart
      368
      175
      Dec 7, 2007
      Southeast NE
      Local Time:
      6:41 PM
      Drive it with the 2.71's for awhile if you do any freeway or interstate driving. you can run 80 all day long. Unless you have an overdrive, then disregard. I give up performance to be able to run out on the road. I do a lot of interstate driving.
      • Like Like x 1
      • Agree Agree x 1
      • AJ/FormS
        AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s
        17,596
        5989
        Jan 19, 2014
        South-Central Manitoba,Canada, 900ftelevation
        Local Time:
        7:41 PM
        From 2.71s to 3.55s is a heckuvan increase ~31%. . This 31% is about the same per cent as downshifting from second gear in an A833 to first gear. The torque increase is throughout the operating range, making the engine feel that much more powerful at all rpms.
        The downside , as mentioned, is that the hiway cruise rpm will be similarly increased, as will the fuel-consumption.
        If you need more power, and need to keep the cruise rpm, or fuel economy;
        then you only have about three/four choices, in order of cost;
        1) a bigger engine,
        2) hot-rodding your engine,
        3) supercharging,
        4) an overdrive trans in conjunction with a rear gear-swap, or an overdrive with a deep low.
        Swapping in a bigger already good-running used engine is usually the cheapest option. And starting with a high-compression one is by far the smarter choice.
        Supercharging is guaranteed to make you smile, and the belt-driven ones are quick and easy
        HotRodding is the usual go-to; but sometimes takes a lotta time and the results are somewhat unpredictable when parts are just thrown together, or the bottom falls out of the budget.
        The overdrive plus gears, is probably gonna be the most expensive, but can have the added benefit of decreasing your hiway fuel consumption. But don't do it for gas savings it will take many years and many miles to break even.
        Gears are quick and relatively easy, and you'll never be sorry from a performance viewpoint.
      • haybag
        187
        17
        Dec 14, 2014
        New Hampshire
        Local Time:
        8:41 PM
        I am putting this duster together as a street car that I can take to the drag strip a couple times a year, will be a mild 5.9 magnum. Don't do much freeway driving, mostly around town driving, so some mid range gears should give me some performance along with drivability.
