[Found!] 8-3/4 741 Pinion Spacer
I need a 741 pinion spacer, crush collar, pinion sleeve, whatever you want to call it. I have everything else but that sleeve to put this thing together.
Let me know if you have one laying around!
Do you have a photo for reference? Probably not if you’re missing the piece but I may have one.
They have a spacer like a sleeve eliminator to set bearing preload.
Ok. My bad then. I haven't set many of those up at all and it's been a long time. I actually HAVE a whole 741 chunk out here with 3.23 gears on it, but I've only swapped an open carrier into it and put the sure grip in something else, so I didn't get into it far enough to remember. But Dr. Diff should still have that, I would think.
I sent an email to cass to see if he’s got one.
741 and 742 have the spacer, 489 has the crush sleeve. The pic is the actual spacer for a 741, it’s on eBay but I’d prefer to get it elsewhere before risking eBay. I don’t have the best luck there.
I completely understand.
