8 3/4 diff. ID. And ratio question
Transmission and Drivetrain Tech
  1. A Body 440 WHY NOT
    A Body 440 WHY NOT Well-Known Member
    119
    36
    Sep 28, 2019
    Jersey
    Local Time:
    10:56 AM
    Hello all,
    So I pulled out the center section, (489 ) and counted the teeth . It has 9 on the pinion and 43 on the ring. Sounds crazy high. Like 478-1. Diff is in fantastic shape and spins like velvet. Has the springs/post unit. Should I change out the gears, or try to trade it ? I am looking for 355 or 323. Haven't fully decided due to the fact that I haven't picked out wheels n tires yet. I am building a 69 dart with a fresh 440 /727 combo. BIG project.
    Thanks.
  2. toolmanmike
    toolmanmike FABO Staff Staff Member FABO Gold Member
    46,881
    31148
    Jan 18, 2006
    Iowa
    Local Time:
    12:56 PM
    Count again? 4.56 4.88? Never heard of a 4.78 44 teeth on the ring gear will give you a 4.88 and that's probably what you have. It would be easier to sell/trade your chunk for a 2.23 or 3.55 unit. Somebody would like your steep gear.
  3. fishy68
    fishy68 Tyr Fryr's Inc. FABO Gold Member
    16,907
    899
    Jan 11, 2005
    Central, IL (Hooterville)
    Local Time:
    12:56 PM
    If you haven't set up gears before I can tell you their not easy to get right for a newbie. You need some specialized tools too. Sell it or trade it for what you want
  4. Demonracer
    Demonracer 71 Demon 00 Ram 16 Chrysler 300S 05 Caravan FABO Gold Member
    2,514
    648
    Jan 31, 2010
    Cleveland, Texas
    Local Time:
    12:56 PM
    As fishy68 said if you are not familiar with changing out gears, trade it off, or have a professional change them for you. If you change them out yourself, you are probably going to end up with a non serviceable chunk that is better suited for a door stop.
    • Agree Agree x 1
    • A Body 440 WHY NOT
      119
      36
      Sep 28, 2019
      Jersey
      Local Time:
      10:56 AM
      I have set up gears before. Prob missed the count by 1. Looks like 488 gears, posi unit. I will place an ad to trade . Thanks
      • Like Like x 2
