8 3/4 Diff. stand
mechanicmark
eastern iowa
Argent Silver
Flat surface for indicator or other things
Gear set up
Flat surface for mag. base indicator or other things.
Yoke side up
If no engine is on stand, simply switch head around.
I don't think I have ever done that. I would post the photos and then go back and edit the text between the attachments.
How do you stack photos with info between them?
Post the photos. Place your comment about the 1st photo above it. Then place your cursor at the bottom right corner of the first photo and hit enter a couple times to create the space to put in your comment. Rinse and repeat.
