1. Jim Kueneman
    Jim Kueneman FABO Gold Member FABO Gold Member
    2,186
    4398
    Jul 26, 2016
    Sonoita, Az
    Local Time:
    3:18 AM
    I am using the stock leaf springs in the '72 Duster and have a pre '68-'70 8 3/4" for it. The perches have been cut off and new ones ready to install. Am I safe expecting with stock springs where the perches sit to be parallel with the bottom of the car? So can I safely align the perches with a -8 degree (with respect to 90 degrees) or so angle to the face of where the center chunk bolts to and have it come out fairly close to -8 degrees when all together? I don't have the K-frame and power train in the car yet and would like to get the rear axle done before that happens.
    Thanks.
  2. DoctorDiff
    DoctorDiff Well-Known Member
    319
    262
    Sep 30, 2012
    Polson, MT
    Local Time:
    3:18 AM
    An 8 degree negative perch angle will bind the U-joints.
    If you want to duplicate the stock A-body pinion angle, weld the perches at 43" on center. The pinion should angle upward 5 degrees when the perches are level with the ground.
    • Like Like x 2
    • Jim Kueneman
      2,186
      4398
      Jul 26, 2016
      Sonoita, Az
      Local Time:
      3:18 AM
      Thanks, I swore I read it should be angled down (maybe that was for maximum traction drag racing). Thanks. I have and order in your cart for reseal kits, brake lines and brake hardware once I go out and measure for the correct lines!
    • DoctorDiff
      319
      262
      Sep 30, 2012
      Polson, MT
      Local Time:
      3:18 AM
      Pinion angle is relative to the transmission center-line, not to the ground. Even though the pinion appears to angle upward, it is actually 2 degrees negative when compared to the transmission.
      • Like Like x 1
      • Thanks! Thanks! x 1
      • Agree Agree x 1
      • Jim Kueneman
        2,186
        4398
        Jul 26, 2016
        Sonoita, Az
        Local Time:
        3:18 AM
        What brake hose will reach from the '72 Duster hard line bracket to the junction block on a late '60s 8 3/4". It is the one that has the block closer to the center of the axle.
      • j par
        j par Well-hung Member
        28,353
        16250
        Jul 2, 2014
        Portland Oregon
        Local Time:
        2:18 AM
        Or like maximum vibration drag racing! LOL:poke:Dr diff has spoken on the subject nuff said...:thumbsup:
