1. DentalDart
    DentalDart Well-Known Member
    699
    503
    Jul 5, 2019
    Las Vegas
    Local Time:
    12:19 PM
    I had a spring pop out when I was cleaning my 3/8 3/4 and was given these guys when I got my car with the parts. I'm pretty sure they are the outer axle seals but am not quite sure how they go in and my seal puller I bought it having a hard time getting the other ones out.
    I could probably use more force, I just am always worried about breaking shit when I take it apart without knowing how to actually do it... Maybe breaking it is how you learn...:rofl: Or asking the geniuses on FABO always seems to work as well . :thumbsup:
  2. TrailBeast
    TrailBeast Slightly Twisted Member
    20,310
    7122
    Mar 11, 2011
    Arizona
    Local Time:
    1:19 PM
    Looking like you pretty much got it figured out.
    That inner seal stops at a ridge in the tube that isn't quite a positive stop because it is tapered some, so slow and easy with the correct size driver gets those.
    A little RTV around the inside of the tube where the seal bottoms is good, and I use my finger to spread a light film in there. (be careful of burrs or sharp edges)
    I knocked the old seals out with a section of tubing and from inside the pumpkin.
    Just set it inside the tube and reached it and smacked it.
    (or a long section all the way through would work just as well.)
    Just did a 8.75 recently.:D
  3. DentalDart
    699
    503
    Jul 5, 2019
    Las Vegas
    Local Time:
    12:19 PM
    So that rubber piece is not needed and will be replaced by the new seal? Is there a correct way these 2 seals go together?
    I have a pipe that may work, well it's the handle to my jack lol .
  4. TrailBeast
    20,310
    7122
    Mar 11, 2011
    Arizona
    Local Time:
    1:19 PM
    If you are asking about the all black rubber coated seal in the housing in your pics then yes, it gets replaced by the green coated metal ones.
    That's why I said a bit of RTV where they seat.
    The all black seals are rubber coated so they seal good on their own.
    The plain metal thinner seals go just in the retainer plate, and both go in with the open side of the seal facing in.
    This might help with some of the visual details.
    Swappin’ Out Axles in Older Mopar “A” Body Cars
  5. DentalDart
    699
    503
    Jul 5, 2019
    Las Vegas
    Local Time:
    12:19 PM
    I like that. I see where it says I don't need those if I went with green bearings? So take the old ones out and don't install the new ones or do like it says and bteer safe than sorry?
  6. TrailBeast
    20,310
    7122
    Mar 11, 2011
    Arizona
    Local Time:
    1:19 PM
    My understanding is that the green bearings have their own seals built in.
    I would still lightly RTV where they seat to the tube.
    I have read where the inner seals can be put in for extra leak protection but not mandatory either way.
    • Like Like x 1
    • DentalDart
      699
      503
      Jul 5, 2019
      Las Vegas
      Local Time:
      12:19 PM
      Well I tried to install the new seals my largest socket is a 36 which was a little small and bent the seal so that's a no go for me. I'm going to put it all in without a seal (unless I manically find one before I get it all hooked up and hope for no leaks.
      On a side note a Copenhagen can is the perfect size to out them in but it is to flimsy to actually get the job done .
    • TrailBeast
      20,310
      7122
      Mar 11, 2011
      Arizona
      Local Time:
      1:19 PM
      That's what I meant by "try to stay on the outside edges of the seal"
    • DentalDart
      699
      503
      Jul 5, 2019
      Las Vegas
      Local Time:
      12:19 PM
      I tried but noting was big enough to fit the outer edges nicely. I'm sure I'll have to get something from. The auto store before I install it and I'll see about grabbing some more.
    • Bad Sport
      Bad Sport HALF A BUBBLE OFF Staff Member FABO Gold Member
      36,454
      16369
      Jun 12, 2010
      The Wolverine
      Local Time:
      3:19 PM
      Pack the inside of the seal with grease before you install them, it will help to keep the spring from popping off.
      • Agree Agree x 1
      • DentalDart
        699
        503
        Jul 5, 2019
        Las Vegas
        Local Time:
        12:19 PM
        Yea I was doing that, the spring is still in the seal, it's juat a bent seal now .
      • DentalDart
        699
        503
        Jul 5, 2019
        Las Vegas
        Local Time:
        12:19 PM
        I did get a little help from the cars owner last night though .
      • fishmens67
        fishmens67 Well-Known Member
        6,275
        3263
        Nov 10, 2012
        idaho
        Local Time:
        2:19 PM
        I hope you are more careful with my teeth. lol
        long and short sections of various size pipe work great for installing internal seals and such
        • Agree Agree x 2
        • DentalDart
          699
          503
          Jul 5, 2019
          Las Vegas
          Local Time:
          12:19 PM
          Teeth are much easier to work on, especially when I've done the procedures before. Here's some teeth I made after doing the root canals
          I heard the pipe comments and sockets of larger sizes I just didn't have one so I tried without.
          • Like Like x 1
