1. WRB426
    WRB426 Insane 4 Mopars FABO Gold Member
    2,237
    173
    Apr 20, 2011
    MA
    Local Time:
    2:38 AM
    Does anybody have the length of an A body 8 3/4? Do you measure from spring perches or end to end? Looking at one Sun. Want to make sure it's not an B body. Thanks for any info.
  2. Bad Sport
    Bad Sport HALF A BUBBLE OFF Staff Member FABO Gold Member
    34,612
    13582
    Jun 12, 2010
    The Wolverine
    Local Time:
    2:38 AM
    IF the perches haven't been moved, an A body will measure 43" center to center on the perches. I put a B body rear in my car and the perches were 44" I moved them in 1/2" each to bolt it in.
  3. SGBARRACUDA
    SGBARRACUDA ROY FABO Gold Member
    13,285
    2980
    Dec 7, 2006
    PLANT CITY FL.
    Local Time:
    2:38 AM
    Flange to flange is 51 1/2", 43" from center perch to center perch.
  4. WRB426
    2,237
    173
    Apr 20, 2011
    MA
    Local Time:
    2:38 AM
    Thanks!! Once again this site is awesome!
  5. tekslk
    tekslk Well-Known Member
    3,109
    33
    Dec 13, 2009
    McClure, Pa
    Local Time:
    2:38 AM
    I think mine is 54 inch from backing plate to plate.
  6. crackedback
    crackedback FABO Gold Member FABO Gold Member
    18,035
    2043
    Aug 7, 2005
    92201
    Local Time:
    11:38 PM
    An A body 8.75 housing will be 52 5/8" from flange to flange.
    Total length with SBP axles is 57 1/8"
    Perches are 43" on center.
  7. Bill Dedman
    Bill Dedman bill dedman Legendary Member
    4,021
    51
    Oct 16, 2007
    Conway, Arkansas
    Local Time:
    1:38 AM
    The generally-inflated price of A Body 8.75" rear ends has resulted in a lot of people using B Body rear end housings in their A Bodies. There are some different width B Body rears, though, so you must be careful to get the narrowest B Body housing that was made.
    We put one in our '64 Valiant, and only had to do two things; moved the spring perches in (toward the center) half an inch on each side, and bought a pair of steel wheels from Stockton Wheel Conpany that had been built with additional back-spacing, to get the tire back into its original position in the wheel-well.
    Overall, doing this was a lot cheaper for us than paying through the nose for an A Body housing.
    I think a lot of people have done this.
    Good luck !!!:cheers:
  8. roadrunnerh
    roadrunnerh Well-Known Member
    2,867
    157
    Jul 11, 2011
    Pittsburgh, PA
    Local Time:
    2:38 AM
    Bill, didn't the cost of the stockton wheels end up canceling the savings of using a B-Body rear?
  9. Bill Dedman
    4,021
    51
    Oct 16, 2007
    Conway, Arkansas
    Local Time:
    1:38 AM
    Around here, A Body 8.75" housings are like gold... and if you find one somewhere else and have to have it shipped to you, that's expensive, too. We got the '66 B Body rear end with a 742 third member, drum-to-drum for $240.00; no shipping. I don't remember how much the wheels were, but the cost of the wheels and complete rear end were cheaper than an A Body housing around here, I am pretty sure..
    Maybe where you live, they're cheaper. That's always a possibility.
  10. dodgedifferent2
    dodgedifferent2 Well-Known Member
    2,383
    234
    Aug 8, 2008
    southwestern, Ontario
    Local Time:
    1:38 AM
    why not chop a c body housing down?
    tons of them in the wreckers and very simple to chop down for 1/4 the price......
  11. roadrunnerh
    2,867
    157
    Jul 11, 2011
    Pittsburgh, PA
    Local Time:
    2:38 AM
    $240 is a great price especially with a 742 carrier! :thumblef:
  12. Bill Dedman
    4,021
    51
    Oct 16, 2007
    Conway, Arkansas
    Local Time:
    1:38 AM
    I have the mechanical aptitude of a ringed-tail monkey, and the tools to match. Not a whole lot of people have a 5-foot lathe at their disposal, and I don't own a lathe of ANY kind, so Il'l leave shortening housings and axles to the people who have the skill and equipment to accomplish something like that. I'm just not equipped to do it...:sad7:
  13. Bill Dedman
    4,021
    51
    Oct 16, 2007
    Conway, Arkansas
    Local Time:
    1:38 AM
    I thought so, too. I would have bought the U-bolts too, but they were torched in the quick-and-dirty removal of the housing from the car. It was refreshing to find a junkyard that actually had, on its property, a whole gang of early (1960-1975) Mopars that were all somewhat intact. Most of the junkyards I find nowdays, have taken all the old stuff to the crusher and operate on the rationale that a 1990-year model car is borderline "too old" for their inventory.
    That 742 chunk has a 2.76 gear in it; perfect for our race car project, with a spool. That's my next project... :prayer:
  14. dodgedifferent2
    2,383
    234
    Aug 8, 2008
    Local Time:
    1:38 AM
    your local welding shop can handle the job ... or a machine shop.
    Take a drive out into the small towns and stop at the local watering hole and mention welding to the old coots in the watering hole and they could direct you to someone.
  15. SpeedracerX
    SpeedracerX Still on this side of the dirt member
    4,402
    98
    Nov 19, 2008
    Irwin, Pa
    Local Time:
    2:38 AM
    I would say $240 was a great price.. I got lucky, found my 8.75 housing, axles, and backing plates at the Mopar Nats a few years back for $350... then I paid $200 for 742 center with .323's (sure grip) .. But by and large my experience is that a-body 8.75's prices just continue to rise.. They're pretty far up there in price around here too.
